Main Menu Wheel Issue
GameWizard
Hi! It's been awhile since I've posted on the forum, but I had a question. Recently, I've been updating everything on my Hyperspin setup for my arcade cab which includes Hyperspin with full Rocketlauncher integration and the most recent versions of emulators and an updated MAME rom set. I started almost completely from scratch and I am using a more logical directory structure for my roms, emulators, etc. I have everything working perfectly that's on the default wheel that's installed on Hyperspin.
For some reason, Colecovision shows up twice on the Main Menu. I can remove it and then re-add it with the main menu wizard and it shows up twice each time. One entry is always with a wheel image, the other is in text. I can play games fine from both entries on the wheel. Apparently, they are using the same database. It's more of an OCD cosmetic issue with the front-end than anything else.
Was wondering if anyone experienced a similar issue and how to resolve it?
Thanks!
Make sure the Wheel Image matches the Exact Case as in the Database.
Sometimes if its not the wheel will sometimes show the image and sometimes not.
If its a direct duplicate maybe just open the Main Menu.xml file with a text editor and check that its not actually in there twice.
