ePSXe plugin help please
sidlalami
Hi guys
I am having an issue with the plugin for ePSXe 2.0
I set up the plugin for petes d3d 1.77
However when i launch the emulator through hyperspin it delects the default ePSXe gpu core v2.0 which i dont want to use
How can i force the system to always load the preffered plugin
Thanks guys
Hi guys
Thanks guys
I think you have to also tell RL which to use... this will also allow you to use different plugins for different games.
Hi
Thanks for getting back to me
When I enter the module settings tab and select video plugin I can only see two options petes gpu opengl and epsxe gpu core version 2.0- the same applies if I click on the rom settings tag
The only other option is to select <default > but this just tries to load petes opengl
Any other suggestions please?
Hi
The only other option is to select but this just tries to load petes opengl
I am on my phone at work right now so I can't even check my own setup. Sounds like most people just use one of these 2... if you really need to switch, I would suggest you ask over at the RL forums as they will know better.
Please do share your solution here if you find one though. May help other people with similar question.
Hi
stimp not having any luck to change the plugin.
So why have all these plugins to see that hyperspin only gives you the choice from two?
there must be way, maybe it has something to do with the module
LOL... again, this has nothing to do with Hyperspin!!!
Plug-in selection is controlled by RocketLauncher, that's why I suggested asking over on their forum.
And I am pretty sure the answer you would get is: "D3D is inferior in every single way and you should not really use it". If you really want a crappier emulation, just use one of the less refined emulators that only run in D3D mode (no support for pete's opengl or any plugins for that matter). Try the PSXfin emulator, super easy to set up, no plugins.
Hi,
The reason I want to use D3D is because my card is not powerful enough, however it runs well on D3D. If I choose to run with openGL, I get issues such as no wgl extensions found etc
The psxfin emulator is way inferior, there are less options available in the plugin, and it does not run some games.
I will certainly try the rl forums
