l4nd0fc0nfu510n Posted September 1, 2010 Posted September 1, 2010 Well, I've got the emulator (PCSXE) and some ROMs. I've set-up all the folder correctly, but when I go into the games wheel for Playstation, it just shows Castlevania over and over and over again (I don't even have that ROM). How do I fix this?
Lailoken Posted September 1, 2010 Posted September 1, 2010 Castlevania is just Hyperspin's example game for Playstation. The list of games that show up in the wheel is pulled from the xml file for that system. It will be at: /Hyperspin/Databases/Playstation/Playstation.xml In order to create an xml file with just the games you have you can download the Rom2XML program here -> http://www.hyperspin-fe.com/forum/showthread.php?t=6734 Just point the program to the directory your games are in and tell it to save the file in the directory I gave above.
l4nd0fc0nfu510n Posted September 1, 2010 Author Posted September 1, 2010 Great, thanks! This will make my MAME, NES, and SNES menus look better as well.
l4nd0fc0nfu510n Posted September 1, 2010 Author Posted September 1, 2010 Well, the menus all work now, but I can't get the games to load. I have a feeling it would work if they were all the same extension, but they aren't. I've got CCDs, ISOs, and BIN/CUEs. I tried converting them to eachother, but then the emulator doesn't load them. Is there any way to make Hyperloader try several different extensions?
ElRoacho Posted September 2, 2010 Posted September 2, 2010 I would try going into HyperHQ and find the Playstation Wheel Settings. Where it says "Extensions:" type all the extension types you want it to detect. For example I have "cue, iso" in mine.
mitchmanhyper Posted April 8, 2015 Posted April 8, 2015 Hi im new here. im trying to config DAEMON tools to work with epsxe and i need it to boot games using DAEMON tools because of the music tracks on some games. i figured out how to change the format of the audio files so they will work in epsxe but only when booted by DAEMON tools. im hopping some one a pro at this. can give me a solid answer on how to make that work. because it not only solve that problem but for other games that dont boot up right. ive gotten Twisted Metal 4, Dead or Alive and pepsiman some of the titles i know that the music doesnt work right to work with epsxe.
urbangangsta101 Posted April 9, 2015 Posted April 9, 2015 CD Based games need a .CUE file to tell DAEMON tools where to find the audio tracks on the (virtual) disc. If you have changed the format of the audio tracks (I'm guessing .mp3 to .wav) you will need to edit your .CUE file to reflect those changes. Just open the .CUE with notepad and change the extensions for the tracks. Other than that, just make/download images that are already correct (.bin+.cue dumps are the best)
SIMPLYAUSTIN Posted April 9, 2015 Posted April 9, 2015 Also I would consider a better Emu... Psxe is a lil behind the curve at the moment and you may find more luck and better compatibility with other Emus. Simply Austin's YouTube
