AppleWin HS/RL Issue - Keyboard Mapping - Space Bar [Solved]
JamesRIves
I've been playing around with he AppleWin emulator lately, and I've run into a unique issue that seems to be specific to Hyperspin/Rocketlauncher. When I launch the AppleWin emulator via Hyperspin/Rocketlauncher and attempt to hit the space bar in a text-based application (for example, a text-based graphics game), the emulator responds by displaying "f5" versus displaying a space. This only occurs when I launch the emulator via the front end. It does not occur when I launch the emulator and load a .dsk image. Seems to be some sort of keymapping issue caused by the front end/launcher.
I am using the correct version of the Applewin emulator. I tried adjusting module settings, but nothing seems to correct the error. Not sure why launching via HS would change the keymapping.
If anyone could assist, I would appreciate it. This one has me perplexed.
Jim
Solved this one.  The module maps the "disk swap" key (F5 on Applewin) to the space bar, so every time you hit the space bar in a game, it registers as "f5".  I changed the hotkey defined in the module, and everything works fine.
Jim
