cowboy Posted May 23, 2018 Posted May 23, 2018 Hi Guys Updated to MAME 195 and no hiscores are saving, i have updated the .dat file and placed in plugin folder in root directory set all paths in mame.ini set hi score to enabled aswell anyone else having same problem
griffin518 Posted May 24, 2018 Posted May 24, 2018 22 hours ago, cowboy said: Hi Guys Updated to MAME 195 and no hiscores are saving, i have updated the .dat file and placed in plugin folder in root directory set all paths in mame.ini set hi score to enabled aswell anyone else having same problem MAME has moved hiscore functionality to a LUA plugin. Go into your config and make sure that hiscore is added to the plugins you're using. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
artman999999 Posted May 24, 2018 Posted May 24, 2018 You may be using an old mame.ini. Make sure "plugins" is set to "1" in mame.ini, and "hiscore" is set to "1" in plugin.ini. You also need a "hi" directory in your mame root folder. It should work fine.
cowboy Posted May 24, 2018 Author Posted May 24, 2018 Thanks for replying guys have not got a plugin.ini , i have got hi folder in plugins folder. i think i might need a new mame.ini as Griffin said
artman999999 Posted May 24, 2018 Posted May 24, 2018 Run mame, then select "plugins" (the last menu option) and turn on hiscore. Then go into "configure options" and save configuration. The plugin.ini file should auto-create and you're good to go.
cowboy Posted May 30, 2018 Author Posted May 30, 2018 Hi Guys Problem solved re installed mame and all its sub folders now working. Thanks for your help ;-)
