Wheel Video/Animation Delay
champrt78
Hey guys, fairly new and can't seem to figure out an easy way to do this.
On my system the videos start up almost immediately when flipping through the wheels (systems and games) is there an easy way to change the delay ?  I found that I can go into each theme.xml and change the delay="0" to delay="3" but that would take ages doing it by hand. I can use PowerGrep (or some other such program) to bulk edit the theme.xml files , but that can lead to disaster if my RegEx is off (initial tests where good tho). So that is along way of asking , is there a master override somewhere? I woulda thought it would be in Hyper HQ but, I can't find it.
Sorry to say but there is no global setting for this on game themes afaik. Its manual load with hypertheme or lbatch changing as you described.
If you just use a default theme per system then its just the one to change per system
