rsmith8900 Posted June 1, 2018 Posted June 1, 2018 Hi, I am using Nvidia Shield and I have Hyperspin working great with Retroarch. Hyperspin will launch the games using Retroarch Cores just fine. My problem is once the game is playing, I can't exit on open a menu and have to Force Close Retroarch for every game. I believe this is a controller setup problem where once I launch a game in Hyperspin, Retroarch controller setting are only using default settings. Can anyone please point me to a good step by step instruction or explain how to get this issue resolved? Thanks in advance for your help.
thatman84 Posted June 1, 2018 Posted June 1, 2018 Did you setup controls yourself? Also when you launch a game do you get the yellow text flash up in bottom left. If so does it say Remap file loaded? Sounds like you dont have any hotkeys or menu combo setup. These are set under Settibg>Input>Hotkeys and Menu Combo Personally i have R2 setup as "enable hotkey", the back touch button as exit/quit and L3 as menu. Also have Start+Select as my menu combo for when I use the 8bitdo snes pad What controller you using? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
