HyperSearch throwing error and not working
Hello,
HyperSearch seems a very good extension for Hyperspin, thanks for the idea.
Anyway, it is impossible for me to make it work. I follow the procedure and I only get a window with this error :
10:13:41  System.Windows.Markup.XamlParseException: 'Unexpected token after end of markup extension.' Line number '91' and line position '264'. ---> System.Xaml.XamlParseException: 'Unexpected token after end of markup extension.' Line number '91' and line position '264'.
  at MS.Internal.Xaml.Parser.MePullParser.<Parse>d__0.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<LogicStream_Attribute>d__6f.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_EmptyElement>d__14.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_Element>d__7.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_ElementContent>d__4a.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_ElementBody>d__23.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_PropertyContent>d__5f.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_NonemptyPropertyElement>d__42.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<P_PropertyElement>d__35.MoveNext()
  at MS.Internal.Xaml.Parser.XamlPullParser.<Parse>d__0.MoveNext()
  at MS.Internal.Xaml.NodeStreamSorter.ReadAheadToEndOfAttributes()
  at MS.Internal.Xaml.NodeStreamSorter.ReadAheadAndSortCtorProperties()
  at MS.Internal.Xaml.NodeStreamSorter.MoveNext()
  at System.Xaml.XamlXmlReader.Read()
  at System.Windows.Markup.WpfXamlLoader.TransformNodes(XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
  at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
  --- End of inner exception stack trace ---
  at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
  at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, Boolean skipJournaledProperties, Uri baseUri)
  at System.Windows.Markup.XamlReader.Load(XamlReader xamlReader, ParserContext parserContext)
  at System.Windows.Markup.XamlReader.Load(XmlReader reader, ParserContext parserContext, XamlParseMode parseMode)
  at System.Windows.Markup.XamlReader.Load(Stream stream, ParserContext parserContext)
  at MS.Internal.AppModel.AppModelKnownContentFactory.XamlConverter(Stream stream, Uri baseUri, Boolean canUseTopLevelBrowser, Boolean sandboxExternalContent, Boolean allowAsync, Boolean isJournalNavigation, XamlReader& asyncObjectConverter)
  at MS.Internal.AppModel.MimeObjectFactory.GetObjectAndCloseStream(Stream s, ContentType contentType, Uri baseUri, Boolean canUseTopLevelBrowser, Boolean sandboxExternalContent, Boolean allowAsync, Boolean isJournalNavigation, XamlReader& asyncObjectConverter)
  at System.Windows.ResourceDictionary.set_Source(Uri value)
  at HyperSearch.MainWindow..ctor()
The machine is :
- Core i5 / 4GB
- Windows 7, 32 bits
- HS 1.3.2
- HL 3.0.0.9
Does someone have an idea ?
Regards
Post your full hypersearch log.
Does this occur on startup or when your trigger the search window?
It is likely something with either your Main Menu.xml or one of the other Xml DBs. Some other people have reported similar problems, but they fixed it themselves by removing something from the xml DBs...I never got a chance to see what was "wrong".
My tools
Steam wheel creator - Generate xml list from Steam profile with artwork and videos
HyperSearch - Integrates search functionality with HyperSpin
Hello,
It already is the full log. The process is killed right after. It is at startup of the program.
All my XML are those provided in the HyperSpin Install zip + Hypersync updated XMLs.
My Hyperspin folder is G:\HyperSpin and HyperSearch is located in G:\HyperSpin\HyperSearch\HyperSearch.exe
Hope it helps, I really would like to use it.
Regards
Sorry, I've been busy...
Ah I misread your error sorry.
Have a look here, this person had the exact same issue and fixed it by installing .net framework 4.5: http://www.hyperspin-fe.com/forum/showthread.php?32517-HyperSearch&p=313078&viewfull=1#post313078
Please let me know if this works for you!
My tools
