microbytemob Posted May 9, 2014 Posted May 9, 2014 hi there was wondering if anyone has got the amiga cd 32 games to boot via hyperlaunch hq? i have no probs booting the amiga cd32 games through fs uae frontend , i can even boot them through winuae loader , when i try to boot a game through hyperlaunch hq i get the workbench loading screen & in the bottom screen it says no configuration file was found ? am i missing something here any help would be much appreciated, also i noticed that the mod.ahk file for fs uae only looks for 7z,zip,adf & hdf but the cd32 games are bin & cue? is this a reason for it not to work?
gigapig Posted May 9, 2014 Posted May 9, 2014 Your best bet is to follow Rons guide and use Winuae. www.hyperspin-fe.com/forum/entry.php?122-My-Guides
microbytemob Posted May 9, 2014 Author Posted May 9, 2014 thx for the link bro (only thing is that his tutorial is for winuae 2.6 ahk module) & the one im using is the latest ahk module 2.7 which uses whdloader instead & not winuae is this still ok to use his tutorial many thx!!!
gigapig Posted May 9, 2014 Posted May 9, 2014 thx for the link bro (only thing is that his tutorial is for winuae 2.6 ahk module) & the one im using is the latest ahk module 2.7 which uses whdloader instead & not winuae is this still ok to use his tutorial many thx!!! It should be fine, there is actually a newer version 2.8 http://www.winuae.net it's unlikely you'll have any problems, but if you do then perhaps give 2.6 a go. Hey why not be a test subject, let us know if it works out and I'll change mine to 2.8 as well
gigapig Posted May 9, 2014 Posted May 9, 2014 In fact in the 7 minutes since my last post I have stopped nibbling the cardboard tube in my cage and installed version 2.8. Everything still works.
microbytemob Posted May 9, 2014 Author Posted May 9, 2014 ha ha yeah i noticed 2.8 has just come out also ill try get this thing to work first , i just cant seem to ouput any ini files from the winuae so i can then ad them to the ahk module folder
gigapig Posted May 9, 2014 Posted May 9, 2014 You don't put them in the module folder they go in the Winuae> configurations> hosts folder. You following the guide??
microbytemob Posted May 9, 2014 Author Posted May 9, 2014 it states on that guys tutorial m8 that you first run winuae n make a settings ini folder for the cd32 then as he states Navigate to H:\HyperSpin\HyperLaunch\Modules\WinUAE. I copied the three files (Commodore Amiga CD32 (Example).ini, Commodore Amiga (Example).ini & Settings (Example).ini) and renamed them as shown
gigapig Posted May 9, 2014 Posted May 9, 2014 Yes so in your winuae modules folder you now have 3 extra files without (Example) in the title. The you'd be interested in is the CD32 ini and you will probably only change Full screen to true. The other 2 files you renamed are only used if you set up CDTV and Amiga. After that step you move on to winuae to create the config file.
