triton2k3 Posted June 2, 2018 Posted June 2, 2018 Besides the obvious, being able to run hyperspin in windows 10, what features of 1.5 do you like, use, or notice a difference? Has anyone spent the time to animate the wheels yet? Not sure i am going to animate. Curious if there’s something I’m not seeing.
dark13 Posted June 2, 2018 Posted June 2, 2018 There are some 3d flash-based animated .swf boxset ready. I'd like to release an animated neo geo set but honestly rendering time is a big problem. A single frame does not take too much time but for a smooth animation you need 90-ish frames per box. Moreover at this point assets should be 8k ready to be time proof, so even with a fast machine rendering would take something like 2 hour per box. The very good thing is animation is locked on frame 0 when the wheel item is not hilighted and animation starts as soon as the game is selected. Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
triton2k3 Posted June 4, 2018 Author Posted June 4, 2018 On 6/2/2018 at 11:12 PM, dark13 said: There are some 3d flash-based animated .swf boxset ready. I'd like to release an animated neo geo set but honestly rendering time is a big problem. A single frame does not take too much time but for a smooth animation you need 90-ish frames per box. Moreover at this point assets should be 8k ready to be time proof, so even with a fast machine rendering would take something like 2 hour per box. The very good thing is animation is locked on frame 0 when the wheel item is not hilighted and animation starts as soon as the game is selected.Agreed. It seems like a lot. Maybe when I actually see it I’ll be into it but right now I haven’t really been interested enough to even try it.Sent from my iPad using Tapatalk
dark13 Posted June 4, 2018 Posted June 4, 2018 Just to get an idea. This was a test with an older HS build, with current build only the selected cart would be animated Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
