Why do i need Joy2Key?
iceflow420
Xpadder can be used in lieu of Joy2Key.....as is preferred albeit you have to pay for a license unlike Joy2Key
[sIGPIC][/sIGPIC]
Sega Saturn Japanese Wheel Project: COMPLETE!! If you have FTP access, find my name and grab the set now!!!
Right, but when I attempt to start up a game I get an error saying it could not find Joy2Key?
Is there something in the ini that need a to be changed? There are no profiles under Joy2Key in Hyperlaunch.
Question: For your HS setup, are you also using the RocketLauncher?
[sIGPIC][/sIGPIC]
If you are, open up HLHQ and see if you have a path set for Joy2Key in either your global or system specific settings....if you do, delete it
[sIGPIC][/sIGPIC]
Another place to check under global (or system specific)->settings->main settings
[sIGPIC][/sIGPIC]
Just adding to sjignacz info. YOu just need to disable the Keymapper, to not use it.
Just take a look at the second image that sjignacz posted, and copy his Keymapper, Enabled = false setting, and you shouldn't have anymore any HyperLaunch warnings about it.
When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS!
Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher).
Ass. Bleasby - RocketLauncher Development Team.
NP ice...glad it worked
[sIGPIC][/sIGPIC]
