defre1976 Posted June 10, 2018 Posted June 10, 2018 hi , I really need some help , because i don't know it anymore . monaco Gp remake => http://forum.arcadecontrols.com/index.php?topic=134445.0 Created a monaco profile in the logitech profiler . But it just don't work . Only Global settings work . I launch the game with a .bat file out of hyperspin using pc launcher . D: cd D:\Monaco GP mgpr.exe -cfg pro_arcade_1360x768.cfg I selected this .bat file in Logitech profiler . Don't work . I selected the .exe out of the folder in Monaco GP . Don't work . Same problem with out run 2006 => http://forum.arcadecontrols.com/index.php?topic=130891.0 tried several .exe out of the folder . don't work Same for the teknoparrot games .only global works . tried with the bat file that use to launch the game out of hyperspin. same shit what is the purpose of using hyperspin , if you always need to exit hyperspin to change the global settings in logitech profiler. pfffff if somebody have any ideas? Also tried on my laptop, and also there the same problem??? how do you guys set up those racing games. monaco gp rotation 120 , out run rotation 270 , initial D rotation 570
gigapig Posted June 10, 2018 Posted June 10, 2018 Firstly this is no fault of Hyperspin like you suggest, you should also post your question on the Rocketlaucher forum or look at the Logitech forum. Can you add a batch file to the profiler? Have you tried adding the exe instead?
defre1976 Posted June 10, 2018 Author Posted June 10, 2018 1 hour ago, gigapig said: Firstly this is no fault of Hyperspin like you suggest, you should also post your question on the Rocketlaucher forum or look at the Logitech forum. Can you add a batch file to the profiler? Have you tried adding the exe instead? Yes i know . But i ask my question also here because some other people also the g25 together with hyperspin. Yes done everything . Ahk . Bat . Exe . No effect in game . And tried all the settings in logitech profiler. No work. For monaco gp i found a solution . In joytokey i use the mouse. And it runs really good. Offcourse i must leave the spring off in global settings. But for the other games?? I already ask my question in the logitech forum. Also in the arcade controller forum. But no reply.
