dpunktw Posted June 21, 2018 Posted June 21, 2018 Hey! Edited this post since I managed to get a bit closer to running my MAME games in HS, but now an error pops up. So I have gotten to the point where the audit is updated and all games are green and running fine through RL. So I launch HS and go the the MAME selection screen and choose a game. Then this error appears (I've included a screenshot below). I check my modules (included a screenshot for that too) and the only thing I see is that my MAME is 0.185 and the module states emulator version 0.166. Do they need to be the same and if so how do I update it? Thanks for any advice!
dpunktw Posted June 21, 2018 Author Posted June 21, 2018 Ok, so I see now that the path leads to the modules folder in HyperSpin (a folder AV Archvist told me to remove in his youtube tutorial). I see there is a modules folder in the RocketLauncher folder as well and in there a MAME.ahk. So should I change the path to that folder instead, if so where/how or should a bring bach the HyperSpin modules folder and keep the path? EDIT: I brought back the modules to the HS folder and all that did was removing the error, games are still not loading, it just stays on the MAME wheel without anything happening. I removed the module folder again BUT that did not bring back the error!!!??? Thanks for any help!
thatman84 Posted June 21, 2018 Posted June 21, 2018 Rewatch Avars 1st video (link in my signature) you need to delete the Hyperspin modules folder. Move you moduals back first and linkhyperspin to rocketlaucher as described in the vid Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
dpunktw Posted June 21, 2018 Author Posted June 21, 2018 Hey! I have followed every step even double checked it all. 1. I have removed modules and INSTALL .. folder 2. installed RL and base media. 3. removed (example) from global.. 4.edited settings.ini (see included png) 5. set MAME Wheel to hyperlaunch. Someone said I should pick path for executable and rom path too (even though archivist doesn't). Should I? 6. picked default frontend path 7.added frontend and set it to default and active (see png). 8.added the rocketlauncher temp and picked it in extract path. That is all, right? Not sure what I've done wrong.
dpunktw Posted June 21, 2018 Author Posted June 21, 2018 OK, so I've reverted all back and did the archivist's tutorial one more time to be sure I followed every step and restarted the computer and now I get this message again every time I try and start a Game in HS, so atleast there is some kind of response from the program even though it's an error.
thatman84 Posted June 21, 2018 Posted June 21, 2018 Hlooking at your second screenshot. Notepad++ displays the path to the settings.ini as J:/Hyperspin? are you changeing the correct file? It’s easy to get confused when multiple files are open Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
dpunktw Posted June 21, 2018 Author Posted June 21, 2018 oh weird.. I took I new screenshot with the correct path to the settings.ini with the changed hyperlaunch path.
thatman84 Posted June 21, 2018 Posted June 21, 2018 That could just be Avars YouTube vid in the background I suppose. remove the last / from the path and double check in RocketLauncherUI > Global that the frontend path correctly points to the Hyperspin.exe file. it does sound like you have done everything but your error states it is looking for Hyperlaunch not RocketLauncher so ther must be a mistake in your settings somewhere. Capitalisations or something Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
dpunktw Posted June 21, 2018 Author Posted June 21, 2018 That did it, removing that last /. Thanks so much!
thatman84 Posted June 21, 2018 Posted June 21, 2018 No probs everything emulation requires names, folder structure and paths to be perfect!! Its a lesson I learned lol Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
