No indication mame is starting
frehley1
I am running hyperspin and rlauncher with about 15 MAME games. When I start one I get no feedback I have made a choice. Eventually (5-6 seconds) the screen fades and the mame game loads.
Is there a way to get a loading screen or message when a game is selected?
It probably shouldnt take that long to load... maybe if you are running from idle usb drive, and even then it would only be the very first game you try.
My best guess without knowing more information would be that you either need to run HS and RL with admin privilages or add an exception for them in whatever av/maleware program you run.
You can set your Log to "troubleshooting" in RLUI, run a game or two, then use pastebin to post the log over on the RL forums and with any luck, someone can tell you exactly where the slowdown is.
Beyond that, enabling fade-in in RLUI should give you a good indication you have selected something.
