Visual Pinball 10 ( VPX )
Wotto
Hi guys - I have worked out Future Pinball and have it running via HS - all good.
VPX is my main 'go-to' however - and I cant work out how to add it into HS?
Only VP8 and 9 show up in the default listing available (  Pic 1 attached- Emulist )  ) and I need to add it somehow I am guessing - and then set rom paths ( to tables? ) etc after the emulator is added.
Starting pointers appreciated - I am assuming it is to do with the area's from the 2nd screenshot  I have attached ( Ste Up Screen )
After VPX I am attempting Pinball Arcade ( Steam ) thru HS - that should be fun :)
Thanks in advance
rename VP8  to Visual Pinball X  and change the extension to vpx
VPX uses the same module as the VP8 and VP9 emulator entries.
most if not all of the VP8 tables run on  VP9 so their is no need to have that emulator in your list.
