GCE VEctrex help
Ryan_Harmonic
Hi just addedd vectrex to my hyperspin using hypersync , and when i go to click vectrex on the wheel i get :
Cannot find GCE vectrx.ini
can anyone help me , im also looking for box and cart art for the console cant seem to find them .
also need module for ParaJVE 0.7.0 but says there is no modules in the module section
thanks for any help
thanks for any help
You using RocketLauncher or 2?
RocketLauncher comes with the module, if not you may need to update with GIT.
As Hyperlaunch 2 is no longer supported all modules were removed to stop confusion.
You should have a ParaJVE module.
Here's the module notes.
Notes:
; To use the built-in roms for this emu, set SkipChecks to "Rom Only" in HLHQ.
; ParaJVE requires Java Runtime Environment 1.5.0+ - Get it here: http://java.com/en/download/index.jsp
; Roms are not needed for this system, they come with the emu
; You must use the official database from HyperList for this module to work
; In order to use the built-in overlays, the romName is being converted to the emu's built in game id found in the configuration.xml. This avoids having to edit the xml manually to change it to HS naming standards. We also don't have to setup overlay files this way too!
ok found it thanks was looking for gce vectrex , any ideas why im getting the .ini message ?
thanks again
Not without your Hyperlaunch log, the only gce ini i can find is in the statistics folder.
Post your log and i'll have a look.
I have just set up a wheel for "Pinball FX2", which intially named "Pinball FX 2"
This was all working fine in Hyperlaunch HQ but when I came to run it through Hyperspin it threw up the error Cannot find "Pinball FX 2.ini"
I'd already renamed the database and media folders but forgot the ini file in the :\Hyperspin\Settings folder. I renamed it to "Pinball FX2.ini" and it now works.
So I think you have the same trouble, either remove the wheel in HyperHQ and start again with the correct naming or do it manually.
