Ultra widebody pinball with 48" playfield possibly???
Hi there!
I´d like to build a virtual pinball with a 48" Samsung screen...
... because I have an empty pinball cabinet from "Gottlieb": Mars - God of War --> http://tinyurl.com/nc3lm3e
This cabinet is an extrem widebdody:
The playfield measures ~ 24.01 inches (= 61cm)
The complete cabinet wide is ~ 25.59 inches (= 65cm)
I tried to fit in my Samsung 46" (!) ... BUT I can throw it COMPLETELY (with original case) (!) INTO the cabinet...
... and still have ~1cm space on both sides :facepalm: I did not like the look very much... --> http://tinyurl.com/lfnjwwk
What if I buy a new 48" Samsung and decase it? --> It is ~24.80 inches (= 63cm) wide WITH it´s case... How small it will become, if I decase it???????
I am sure it would be much nicer!!!!! --> http://tinyurl.com/qggbxja
I am a little bit confused, that I can´t find an existing 48" pinball cab....
Do I miss something??? Will it work fine? What do you think???
Thanks for advice, regards, Andy :beer:
Hey Luckydogg420!
Thanks for the input!
I would love to insert the playfield from above:
a) I like the idea, that I could remove the playfield easily ( I don´t want to "nail" it inside the cab) ----> I could access all the parts inside the cab, e.g. PC, Speakers, etc.
B) If I decase the tv, it is easier to have the original plunger and the buttons in a fine height (not too low installed).
Regards, Andy :tee:
.... mmmhhhh... I wonder if other cab builders "nail" or "glue" or "fix" their playfield monitor into the cab with no easy way to take it out again some day...???
... I have seen a pinball cab where the owner inserted the playfield from above:
It was a little bit tricky and he had to cut into the wood on one side a little bit more.
Then he could insert the playfield first with a special angle on ONE side, and then on the other side...
I can´t find the post anymore... Does anybody has a link to this project...???? (I thougt it was a builder in Germany !?)
Thanks, Andy :-)
