bleasby Posted June 12, 2014 Posted June 12, 2014 Did you pressed the multigame ey at least one time after the game was running? We need a log with that. When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
RetroJay Posted June 12, 2014 Author Posted June 12, 2014 bleasby said: Did you pressed the multigame ey at least one time after the game was running?We need a log with that. Yeah i did like 20 times just to be sure... i'll do it again, and i changed it to this button "§" just so you know 17:10:08:550 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 17:10:08:551 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1366x768 (1366x728 work) AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 17:10:08:551 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1366 h768 17:10:08:551 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\HyperLaunch.exe exists 17:10:08:552 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.0.9 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 899072 bytes Created: 3/27/2014 - 4:15:08 Modified: 5/26/2014 - 8:49:27 17:10:08:552 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\gdip.ahk exists 17:10:08:567 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 17:10:08:567 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:567 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\RIni.ahk exists 17:10:08:577 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:10:08:577 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:578 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\CLR.ahk exists 17:10:08:579 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 17:10:08:580 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:580 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\COM.ahk exists 17:10:08:583 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:10:08:584 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:584 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\JSON.ahk exists 17:10:08:585 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:10:08:586 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:586 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Fade Init.ahk exists 17:10:08:587 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:587 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:587 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\HyperPause Init.ahk exists 17:10:08:588 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:589 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:589 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Keymapper Init.ahk exists 17:10:08:590 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:591 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2485 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:591 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\MultiGame Init.ahk exists 17:10:08:591 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:592 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:592 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Statistics Init.ahk exists 17:10:08:592 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:593 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:593 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Fade.ahk exists 17:10:08:596 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:597 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26644 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:597 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\HyperPause.ahk exists 17:10:08:619 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:620 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 326352 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:620 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Keymapper.ahk exists 17:10:08:623 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:623 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 27844 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:623 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\MultiGame.ahk exists 17:10:08:627 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:628 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28070 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:628 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Bezel.ahk exists 17:10:08:631 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:631 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 21407 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:632 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Statistics.ahk exists 17:10:08:633 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:634 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26089 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:634 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 17:10:08:642 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:642 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:642 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Shared.ahk exists 17:10:08:649 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:650 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 65137 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:650 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\XHotkey.ahk exists 17:10:08:654 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:654 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28659 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:654 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib\Fade Animations.ahk exists 17:10:08:658 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 17:10:08:658 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 48181 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:658 | HL | INFO | +0 | Main - HyperLaunch received "Sony PlayStation" and "Final Fantasy VII (USA) (Disc 1)" 17:10:08:668 | HL | INFO | +0 | Main - Final Fantasy VII (USA) (Disc 1) is using the default emulator: ePSXe 17:10:08:668 | HL | INFO | +0 | Main - Checking for a [ePSXe] section in D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Settings\Sony PlayStation\Emulators.ini 17:10:08:668 | HL | INFO | +0 | Main - Found [ePSXe] in D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Settings\Sony PlayStation\Emulators.ini 17:10:08:669 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Modules\ePSXe\ePSXe.ahk exists 17:10:08:670 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4664 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:671 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 17:10:08:671 | HL | INFO | +0 | Main - Final Fantasy VII (USA) (Disc 1) will use module: D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Modules\ePSXe\ePSXe.ahk 17:10:08:688 | HL | INFO | +31 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 17:10:08:691 | HL | INFO | +0 | Main - INI Keys read 17:10:08:691 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\7z.exe exists 17:10:08:692 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:693 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\7z.dll exists 17:10:08:693 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 5/26/2014 - 8:49:27 Modified: 5/26/2014 - 8:49:27 17:10:08:694 | HL | INFO | +0 | CheckPaths - Started 17:10:08:694 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).7z 17:10:08:694 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\Final Fantasy VII (USA) (Disc 1).7z 17:10:08:694 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\*.7z 17:10:08:694 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).zip 17:10:08:694 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\Final Fantasy VII (USA) (Disc 1).zip 17:10:08:694 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\*.zip 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).cue 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\Final Fantasy VII (USA) (Disc 1).cue 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\*.cue 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).bin 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\Final Fantasy VII (USA) (Disc 1).bin 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1)\*.bin 17:10:08:695 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).iso 17:10:08:696 | HL | INFO | +0 | CheckPaths - Found rom: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).iso 17:10:08:696 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX\ePSXe.exe exists 17:10:08:696 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 381952 bytes Created: 5/26/2014 - 10:18:56 Modified: 11/9/2012 - 11:02:08 17:10:08:696 | HL | INFO | +0 | CheckPaths - Ended 17:10:08:697 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 frontendPID = 7076 frontendPath = D:\Games\Arcade\HyperSpin v1.3.2.0 frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = D: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX\ePSXe.exe emuPath = D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX emuName = ePSXe emuExt = exe romPath = D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX romPathFromIni = D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX romExtension = .iso romExtensionOrig = .iso romExtensions = 7z|zip|cue|bin|iso executable = ePSXe.exe systemName = Sony PlayStation dbName = Final Fantasy VII (USA) (Disc 1) romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1366 originalHeight = 768 dtEnabled = true dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Media\Fade HLDataPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Data HLMediaPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Media HLErrSoundPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Media\Sounds\Error modulesPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Modules moduleFullName = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Modules\ePSXe\ePSXe.ahk moduleName = ePSXe modulePath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Modules\ePSXe moduleExtension = ahk moduleExtensionsPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions libPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Lib 7zEnabled = false 7zPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\7z.exe 7zDllPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = D:\Games\Arcade\hstemp 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = true mgKey = § mgBackgroundColor = 6E000000 mgSidePadding = 5 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = grow mgUseGameArt = true mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapper = xpadderFullPath = D:\Games\Arcade\HyperSpin v1.3.2.0\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = D:\Games\Arcade\HyperSpin v1.3.2.0\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\HyperSpin defaultProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\_Default systemProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\Sony PlayStation xPadderSystemProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\Sony PlayStation\_Default emuProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\Sony PlayStation\ePSXe romProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\Sony PlayStation\Final Fantasy VII (USA) (Disc 1) blankProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\blank HyperLaunchProfile = D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\Profiles\\HyperLaunch bezelEnabled = false statisticsEnabled = true 17:10:08:697 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 17:10:08:697 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 17:10:08:697 | HL | INFO | +0 | BuildScript - Loaded MultiGame.ahk scripts 17:10:08:697 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 17:10:08:698 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 289 17:10:08:699 | HL | INFO | +0 | BuildScript - Module: MEmu = ePSXe MEmuV = v1.8.0 MURL = http://www.epsxe.com/ MAuthor = djvj & Shateredsoul & brolly MVersion = 2.0.3 MCRC = 8E174373 iCRC = D6E3720 MID = 635038268888210842 MSystem = "Sony PlayStation" ;---------------------------------------------------------------------------- ; Notes: ; epsxe can't deal with bin/cue dumps with more than one audio track if you load the cue file directly. ; For these to work you must mount the cue on daemon tools and let epsxe boot the game from there. ; You need to make sure you have a SCSI virtual drive on Daemon Tools, NOT a DT one. ; ; Extract all your BIOS files to the bios subfolder. Then goto Config->Bios and select the bios you wish to use. ; ; Go to Config->Video then choose a plugin. Pete's OpenGL line is preffered ; Click Configure (under video plugin) and choose fullscreen and set your desired resolution. Video options/results will vary based on the plugin you choose. ; ; If you are using images with multiple tracks, set your extension to cue (make sure all your cues are correctly pointing to their tracks). ; Go to Config->Cdrom->Configure button and select the drive letter associated with your daemon tools virtual drive. ; ; ePSXe will ONLY close via Escape, it will bug out with all other forms of closing a normal program. Do not edit CloseProcess! ; ; TurboButton will only work with DX7 video plugin. Turbo key by Hypnoziz ; ; epsxe stores its settings in the registry @ HKEY_CURRENT_USER\Software\epsxe\config ; plugins store their settings in the registry @ HKEY_CURRENT_USER\Software\Vision Thing\PSEmu Pro ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" turboButton := IniReadCheck(settingsFile, "Settings", "turboButton","F12",,1) ; Key mapping for turbo button assignment slowBoot := IniReadCheck(settingsFile, "Settings", "slowBoot","false",,1) ; If true, force emulator to show bios screen at boot enableAnalog := IniReadCheck(settingsFile, "Settings", "enableAnalog","true",,1) ; If true, enables analog controls at start of game for you, so you don't have to press F5 7z(romPath, romName, romExtension, 7zExtractPath) epsxeExtension := InStr(".cue|.img|.iso|.mdf",romExtension) ; the psx extensions supported by the emu SetKeyDelay, 50 ; turboButton := xHotKeyVarEdit(turboButton,"turboButton","~","Add") xHotKeywrapper(turboButton,"TurboProcess") turboEnabled = 0 ; Initialize turbo state slowBoot := If (slowBoot = "true") ? "-slowboot" : "" ; Mount the CD using DaemonTools If (epsxeExtension && dtEnabled = "true" ) { Log("Module - Daemon Tools is enabled and " . romExtension . " is a supported DT extension.") DaemonTools("mount",romPath . "\" . romName . romExtension) errorLvl := Run(executable . " -nogui " . slowBoot, emuPath) } Else { Log("Module - Sending rom to emu directly as Daemon Tools is not enabled or " . romExtension . " is not a supported DT extension.") errorLvl := Run(executable . " -nogui " . slowBoot . " -loadiso """ . romPath . "\" . romName . romExtension . """", emuPath) } If errorLvl != 0 ScriptError("Error launching " . executable . "`, closing module.") WinWait("ePSXe ahk_class EPSX") WinWaitActive("ePSXe ahk_class EPSX") FadeInExit() If enableAnalog = true { Sleep, 1500 ; necessary otherwise epsxe doesn't register the key Send, {F5 down}{F5 up} } Process("WaitClose", executable) If (epsxeExtension && dtEnabled = "true" ) DaemonTools("unmount") 7zCleanUp() FadeOutExit() ExitModule() TurboProcess: If (turboEnabled = 0) { Send, {Delete}{End}{End}{Delete} turboEnabled = 1 } Else { Send, {Delete}{End}{Delete} turboEnabled = 0 } Return HaltEmu: Send, !{Enter} Sleep, 200 Return MultiGame: ; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = " . mgRomName ; Unmount the CD from DaemonTools If ( romExtension = ".cue" && dtEnabled = "true" ) DaemonTools("unmount") Sleep, 500 ; Required to prevent DT from bugging ; Mount the CD using DaemonTools If ( romExtension = ".cue" && dtEnabled = "true" ) DaemonTools("mount",selectedRom) Return RestoreEmu: WinActivate, ahk_id %emulatorID% Send, !{Enter} Return CloseProcess: FadeOutStart() SetWinDelay, 50 Log("Module - Sending Escape to close emulator") ; WinClose("ePSXe ahk_class EPSX") ; epsxe remains running as a process when this is used Send, {Esc down}{Esc up} ; DO NOT CHANGE Return 17:10:08:699 | HL | INFO | +0 | CheckFile - Checking if C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe exists 17:10:08:707 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription DAEMON Tools Lite FileVersion 4.49.1.0356 InternalName DTLite.exe LegalCopyright © 2000-2013 Disc Soft Ltd. OriginalFilename DTLite.exe ProductName DAEMON Tools Lite ProductVersion 4.49.1.0356 CompanyName Disc Soft Ltd File Size: 3696912 bytes Created: 3/4/2014 - 11:19:52 Modified: 3/4/2014 - 11:19:52 17:10:08:707 | HL | INFO | +0 | BuildScript - Loaded MultiGame scripts 17:10:08:707 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 17:10:08:707 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 17:10:08:707 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 17:10:08:707 | HL | INFO | +0 | Main - Module is built 17:10:08:707 | HL | INFO | +0 | CheckFile - Checking if D:\Games\Arcade\HyperSpin v1.3.2.0\HyperLaunch\AutoHotkey.dll exists 17:10:08:708 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 3/27/2014 - 4:15:08 Modified: 5/26/2014 - 8:49:27 17:10:08:709 | HL | INFO | +0 | Main - Running module 17:10:08:709 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 17:10:08:833 | MD | INFO | +N/A | Module initialized 17:10:08:836 | MD | INFO | +0 | StartModule - Started 17:10:08:836 | MD | INFO | +0 | StartModule - MEmu: ePSXe MEmuV: v1.8.0 MURL: http://www.epsxe.com/ MAuthor: djvj & Shateredsoul & brolly MVersion: 2.0.3 MCRC: 8E174373 iCRC: D6E3720 MID: MSystem: "Sony PlayStation" 17:10:08:836 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sony PlayStation" 17:10:08:836 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to HyperLaunch: 17:10:08:836 | MD | INFO | +0 | StartModule - Ended 17:10:08:837 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 17:10:08:837 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 17:10:08:837 | MD | INFO | +0 | Module Setting - turboButton: F12 17:10:08:837 | MD | INFO | +0 | Module Setting - slowBoot: false 17:10:08:837 | MD | INFO | +0 | Module Setting - enableAnalog: true 17:10:08:837 | MD | INFO | +0 | Module - Daemon Tools is enabled and .iso is a supported DT extension. 17:10:08:837 | MD | INFO | +0 | DaemonTools - Started - action is mount 17:10:08:838 | MD | DEBUG1 | +0 | DaemonTools - Received file: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).iso 17:10:08:861 | MD | INFO | +31 | CreateMGRomTable - Started 17:10:08:861 | MD | DEBUG1 | +0 | CreateMGRomTable - romTable does not exist, creating one for "Final Fantasy VII (USA) (Disc 1)" 17:10:08:861 | MD | INFO | +0 | CreateRomTable - Started 17:10:08:861 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Final Fantasy VII (USA) (Disc 1)" and "(Disc" 17:10:08:861 | MD | DEBUG1 | +0 | CreateRomTable - "Final Fantasy VII (USA) (Disc 1)" contains "(Disc" 17:10:08:861 | MD | DEBUG1 | +0 | CreateRomTable - Checking New Rom path: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX 17:10:08:862 | MD | DEBUG1 | +0 | CreateRomTable - Now looping in: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc* 17:10:08:862 | MD | DEBUG1 | +0 | D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).iso 17:10:08:862 | MD | DEBUG1 | +0 | CreateRomTable - Looking for: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disciso 17:10:08:862 | MD | DEBUG1 | +0 | CreateRomTable - Adding found game to Rom Table: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).iso 17:10:08:862 | MD | DEBUG1 | +0 | D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 2).iso 17:10:08:862 | MD | DEBUG1 | +0 | CreateRomTable - Looking for: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disciso 17:10:08:862 | MD | DEBUG1 | +0 | CreateRomTable - Adding found game to Rom Table: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 2).iso 17:10:08:862 | MD | DEBUG1 | +0 | D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 3).iso 17:10:08:863 | MD | DEBUG1 | +0 | CreateRomTable - Looking for: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disciso 17:10:08:863 | MD | DEBUG1 | +0 | CreateRomTable - Adding found game to Rom Table: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 3).iso 17:10:08:897 | MD | INFO | +32 | CreateRomTable - Ended, 5 Loops to create table. 17:10:08:897 | MD | INFO | +0 | CreateMGRomTable - Ended 17:10:09:394 | MD | INFO | +499 | DaemonTools - Running DT with: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe -mount scsi, 0, "D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\Romfiles\PSX\Final Fantasy VII (USA) (Disc 1).iso" 17:10:10:156 | MD | INFO | +764 | DaemonTools - Ended 17:10:10:157 | MD | INFO | +0 | Module Run - Running: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX\ePSXe.exe -nogui 17:10:10:224 | MD | DEBUG1 | +63 | Module Run - "ePSXe.exe -nogui " Process ID: 5736 17:10:10:225 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: AutoPlay | Class: #32770 | State: 0 | X: 516 | Y: 101 | Width: 334 | Height: 203 | Window HWND: 0x140e54 | Process ID: 3748 | Process Path: C:\Windows\explorer.exe 17:10:10:225 | MD | INFO | +0 | Module WinWait - Waiting for ePSXe ahk_class EPSX 17:10:10:490 | MD | DEBUG1 | +265 | GetActiveWindowStatus - Title: ePSXe - Enhanced PSX emulator | Class: EPSX | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0xc90cae | Process ID: 5736 | Process Path: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX\ePSXe.exe 17:10:10:491 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: ePSXe - Enhanced PSX emulator | Class: EPSX | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0xc90cae | Process ID: 5736 | Process Path: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX\ePSXe.exe 17:10:10:491 | MD | INFO | +0 | Module WinWaitActive - Waiting for "ePSXe ahk_class EPSX" 17:10:11:701 | MD | DEBUG1 | +1217 | GetActiveWindowStatus - Title: ePSXe - Enhanced PSX emulator | Class: EPSX | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0xc90cae | Process ID: 5736 | Process Path: D:\Games\Arcade\HyperSpin v1.3.2.0\Emulators\PSX\ePSXe.exe 17:10:13:295 | MD | INFO | +1591 | Module Process - WaitClose ePSXe.exe 17:10:17:657 | MD | DEBUG1 | +4352 | CloseProcess started, user requested to end launched application 17:10:17:658 | MD | INFO | +16 | Module - Sending Escape to close emulator 17:10:17:751 | MD | DEBUG1 | +93 | CloseProcess ended 17:10:19:538 | MD | INFO | +1779 | DaemonTools - Started - action is unmount 17:10:19:539 | MD | INFO | +0 | DaemonTools - Running DT with: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe -unmount scsi, 0 17:10:20:217 | MD | INFO | +686 | DaemonTools - Ended 17:10:20:218 | MD | INFO | +0 | StopGlobalUserFeatures - Starting 17:10:20:218 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 17:10:20:218 | MD | INFO | +0 | ExitModule - Started 17:10:20:218 | MD | INFO | +0 | Starting Updating Statistics: 17:10:20:218 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 17:10:20:218 | MD | DEBUG2 | +0 | gameSectionStartTime:238979491 17:10:20:218 | MD | DEBUG2 | +0 | ElapsedTime:11 17:10:20:219 | MD | DEBUG2 | +0 | Statistics game name without disc info: Final Fantasy VII (USA) 17:10:20:219 | MD | DEBUG2 | +0 | Statistics cleared game name: Final Fantasy VII 17:10:20:274 | MD | DEBUG2 | +47 | Loaded game statistics from ini files: Number_of_Times_Played: 3 Last_Time_Played: torsdag juni 12, 2014 05:09:16 Average_Time_Played: 23 Total_Time_Played: 69 System_Total_Played_Time: 853 Total_Global_Played_Time: 1716 17:10:20:274 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 4 Last_Time_Played: torsdag juni 12, 2014 05:10:20 Average_Time_Played: 20 Total_Time_Played: 80 System_Total_Played_Time: 864 Total_Global_Played_Time: 1727 17:10:20:275 | MD | DEBUG2 | +0 | Aggregated Final Statistics to multidisc games: Number_of_Times_Played: 4 Last_Time_Played: torsdag juni 12, 2014 05:10:20 Average_Time_Played: 20 Total_Time_Played: 80 System_Total_Played_Time: 864 Total_Global_Played_Time: 1727 17:10:20:312 | MD | INFO | +47 | Game section statistics updated. 17:10:20:312 | MD | INFO | +0 | ExitModule - Ended 17:10:20:313 | MD | INFO | +0 | End of Module Logs 17:10:20:403 | HL | INFO | +11700 | Main - Module ended, exiting HyperLaunch normally 17:10:20:403 | HL | INFO | +0 | ExitScript - Started 17:10:20:407 | HL | DEBUG1 | +0 | ExitScript - Putting HyperSpin.exe back in focus 17:10:20:416 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 17:10:20:427 | HL | INFO | +16 | ExitScript - Ended
rfancella Posted June 13, 2014 Posted June 13, 2014 RetroJay said: guess it cant be explained then? RetroJay, Give it some time. None of us here get paid to do this. And Bleasby is already worn thin working on all things HyperLaunch. Give it a couple days, if there is no response, try posting this over at HyperLaunch.net. This exact same setup works with other systems? Do you have anything that would change your keymapping? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
RetroJay Posted June 13, 2014 Author Posted June 13, 2014 rfancella said: RetroJay,Give it some time. None of us here get paid to do this. And Bleasby is already worn thin working on all things HyperLaunch. Give it a couple days, if there is no response, try posting this over at HyperLaunch.net. This exact same setup works with other systems? Do you have anything that would change your keymapping? Thanks, Ron You're right man, sorry. Well i dont know of anything that would change it, and i dont know if you can see it in the log but i pressed both NUMSUB and my changed key "§" when i tryed it out and nothing happened... well you du what you can with this, it could be cool if it worked, and if this is some kind of but its reported to you guys by this thread at least... so you do what you have to do and i thank you so much for even trying. Hyperspin is still super cool in my eyes and its gotten pretty far, and you know how you get when seeing something cool as a CD menu for multi-cd-games its eye-gasm for a perfectionist like me and its really teasing when its not working haha Again, Thanks alot you guys!
