Multiple romextension=
triton2k3
I am trying to us Rom Path Only on a wheel. When I put true I am only getting 1 file type roms on the wheel. I have 2 or 3 different file types. In the RomExtension= field on the .ini can I list multiple types and if so what would separate them different types?
I basically have 2 different file types in 2 different locations and when I use rom path only only 1 type and location is pulling up in my wheel.
Not sure you can do two locations in HQ.
The good news is that if you are using RL to launch stuff, then settings in HQ are just to populate the wheel, thats it. Create dummy files named correctly and they will show up.
The character to list more than 1 extension is called a "pipe" I believe. Just a straight vertical line: zip|rar
Oh maybe RL uses the pipe and HQ is just a comma (no space). Cant remember which is which now, away from home atm.
Dummy files did not do it. The , worked. I put everything in the same folder and put the 3 file types.
Thanks again
