Stuck on black screen on Hyperspin after selecting MAME
NanasPanas
Hi folks. I would appreciate help with this new problem. I  upgraded to Hyperspin 1.51 a few weeks ago without any issues. This morning, I ran into a new problem. Hyperspin main menu loads normally, but when I select the MAME wheel, a black screen appears and nothing else happens. It doesn't respond to Escape, so I have to use Task Manager to end Hyperspin. Other (non MAME) wheels load normally. The only thing I can think of is that I performed a Windows Update yesterday.
The Hyperspin log.txt reads:
11:41:51 AM |  HyperSpin Started
11:41:51 AM |  Going FullScreen
11:41:51 AM |  Checking for updates
11:41:51 AM |  Update Check Complete
11:41:51 AM |  Startup program unavailable
11:41:51 AM |  Error intializing joysticks
11:41:52 AM |  Menu Mode is multi
11:41:52 AM |  Loading Main Menu.xml
11:41:52 AM |  Main Menu.xml successfully loaded
11:41:52 AM |  Main Menu wheel loaded successfully
11:41:56 AM |  Loading MAME.xml
11:41:56 AM |  roms_only is true, checking files
11:41:59 AM |  Main Menu.xml successfully loaded
11:42:11 AM |  Quiting Hyperspin
11:42:11 AM |  Bye!
I would check your Mame database if this only effects Mame. It could also be a bad piece of wheel art or theme maybe even the Mame settings file found in the settings folder.
Anyone else have any ideas?
I replaced MAME.ini in the Hyperspin/Settings/ folder with the default one, and the problem was resolved. I'll have to hunt down what was the specific line that triggered it.
Thank you @gigapig !
  • 1 year later...
