relic Posted May 30, 2014 Posted May 30, 2014 Hi guys i really dont get whats happened usually when a default theme doesent work at least an xml shows inside when it enters but for me with mame nothing shows not even a xml wheel listing my theme is name default.zip and my xml ive tried replacing as well as my default theme but at same time its acting like as if mame is corrupt please help me out guys. i cant even escape from the mame default in hyperspin - i check the log no errors show - 09:08:11 PM | HyperSpin Started 09:08:11 PM | Going FullScreen 09:08:11 PM | Checking for updates 09:08:11 PM | Update Check Complete 09:08:11 PM | Startup program unavailable 09:08:11 PM | Playing intro video 09:08:12 PM | Error intializing joysticks 09:08:12 PM | Menu Mode is multi 09:08:12 PM | Loading Main Menu.xml 09:08:12 PM | Main Menu.xml successfully loaded 09:08:13 PM | Main Menu wheel loaded successfully 09:08:15 PM | Loading MAME.xml 09:08:16 PM | Main Menu.xml successfully loaded 09:08:22 PM | Quiting Hyperspin 09:08:22 PM | Bye! and my hq settings are normal nothing is ticked sept the basics are set for it 100%
SIMPLYAUSTIN Posted May 30, 2014 Posted May 30, 2014 MAME working outside of HS? Simply Austin's YouTube
relic Posted May 30, 2014 Author Posted May 30, 2014 austin MAME working outside of HS? yes - only inside theme is going completely blank 100%
relic Posted May 30, 2014 Author Posted May 30, 2014 i guess no one knows how to sort my problem oh well im gonna have to do a fresh install which is gay 100%
relic Posted May 31, 2014 Author Posted May 31, 2014 do a fresh install which is gay then replace mame theme with the orginal and after add the previous one i had not sure what caused it but thanks relic 100%
