Daphne help
lopez888
Are you using the Daphne roms for your rom path in RL
11:12:19:389 | RL |      INFO  | +15    | CheckPaths - Found rom: C:\HYPERSPIN\HyperSpin\Emulators\Daphne 2\roms\lair.zip
                    romPath := "C:\HYPERSPIN\HyperSpin\Emulators\Daphne 2\roms"
                    romPathFromIni := "C:\HYPERSPIN\HyperSpin\Emulators\Daphne 2\framefile|C:\HYPERSPIN\HyperSpin\Emulators\Daphne 2\roms"
                    romExtension := ".zip"
your rom path for this emulator should be to your Daphne frame files,  and the extension should be txt,  you don't need the rest.
I'm not sure but I think the Daphne emulator requires you to keep your framefiles with your Mpeg files   but you can make duplicate copies of your frame files and keep the duplicates in a single folder.
This way you can have a single rom  path to your texfiles
i've pointed RL to roms and the framefile folder
only because there was nothing in the framefile folder
i understand now that's where the text files are supposed to go
i've only got a text file for ace, i audit the system and it comes up green, the rest are red (they are all lit up green when i point RL to the Roms folder as well as the framefile folder)
still getting "could not load bitmap tongue.pngics/led0.bmp" 1,2,3,4,5,6,,7,8,9,10,11,12,13,14,15,16 /player1.bmp 2/picslives.bmp/credits.bmp/saveme.bmp/gamenowook.bmp/overlayleds1.bmp/lsp1450font.bmp = video initialization failed
then ahk_class_SDL_App
getting somewhere, loaded it again
gets into the game sort of,
says could not open file :C/Daphne/mpeg2/ACE/sa-slates.m2v
read daphne_log.txt for help
found txt file for galaxy (put in framefile folder) , tried it
got " could not open file : D/Daphne/MPEGS/galaxy/galaxy.m2v
think i know what im doing now
the txt file for ACE when you open it , at the top, needs the path to be pointed at Daphne folder > mpeg2 folder  > ACE folder
loads up now !
