vincefaro Posted September 19, 2018 Posted September 19, 2018 I am having a tough time getting my system to work. I'm not sure if it is a setting that i pressed? Now it is broke. Both HS and RL will hang up on this screen when I run multiple emulators including Mame. The emulators ALL work outside of the software. Here is what's weird, If I run RLUI and go to MAME (ver .201) I say choose 1942. It will run , I will try another game it might or might not run , I go back to 1942 or any other game and it gives me this screen. For HS I get this screen every time . I can't figure this out. Help! RocketLauncher.txt
Icesurf3r Posted September 20, 2018 Posted September 20, 2018 I had a similar issue and all I needed to do to solve it was launch Hyperspin as an Administrator. Once I did that everything worked fine and I no longer got the error. Might be worth giving it a try.
vincefaro Posted September 20, 2018 Author Posted September 20, 2018 Hi, I just tried that . It did not work. Since I posted this , I decided to reinstall, HS and RL from scratch. It wasn't too bad. I now have everything working. again, I thought when I did the install , i would find something that was wrong with the old version compared to the fresh install. So far I have not found what the reason is. However , The new HS and RL are working again.
myselfroberthustly Posted September 22, 2018 Posted September 22, 2018 Am too facing the same problem. I decided to reinstall, HS and RL from scratch. It wasn't too bad. I now have everything working. again, I thought when I did the install, i would find something that was wrong with the old version compared to the fresh install. So far I have not found what the reason is. Thanks and Regards, 3ds emulator download Cartoon HD download playbox hd download
ninja2bceen Posted September 26, 2018 Posted September 26, 2018 For all things hyperspin tutorial sub to my channel Https://www.Youtube.com/c/planetgeekdom Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
