pmindemann Posted October 30, 2018 Posted October 30, 2018 Hello all, I have a recently installed build of HyperSpin (1.5.1.0) and RocketLauncher (1.2.0.1) with a single-wheel solution based around MAME. In addition to the regular MAME games, I have added a few PC-based fighting games, such as Mortal Kombat XL and the Double Helix/Iron Galaxy version of Killer Instinct. I've set these up via the "Alternate Emulator" option in RocketLauncher, and Mortal Kombat launches well, but Killer Instinct generates the following error (or one like it, with varying number codes): Quote There was an error waiting for the window "ahk_pid 7264". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. Now, Killer Instinct will run through a few intro screens just fine, but then RL generates the above error and goes back out to the main wheel screen (or if I just run it through RL, it'll close to the desktop). Meanwhile, Killer Instinct continues playing in the background (I can hear the audio). Here are a few things I've tried and/or verified: This Steam version of Killer Instinct will run fine when launched outside of HyperSpin and RocketLauncher (i.e., just through the desktop). Killer Instinct will ALSO run fine if I add it in Hyper HQ (linked directly to the .exe) and add it as a separate wheel item next to MAME. Running Killer Instinct through either HyperSpin (as part of the MAME wheel using PC Launcher) or directly via RocketLauncher (using PC Launcher) will generate the error. Running it directly as an .exe (i.e., through HyperHQ, as noted above) does NOT generate the error. Setting the "Fade In" to either True or False in either the MAME or the PC Games Settings/Fade-General tab makes no difference (I'm not sure if I can set it per game, but again, I'm not seeing a difference either way). I have Steam set to auto-run at PC startup. I have not set-up any Steam credentials in RL, since my Steam version of Mortal Kombat is set-up the same way as Killer Instinct and runs fine. Skip Checks are set to False in both PC Games and MAME RL settings. I love this game and would really like to have it as part of my primary MAME wheel the way I've been able to add the newest Mortal Kombat. Thank you in advance for any advice. Following are my troubleshooting logs from RL. Paul 22:00:32:025 | RL | INFO | +N/A | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com) 22:00:32:072 | RL | WARNING | +47 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 22:00:32:245 | RL | DEBUG | +172 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 22:00:32:245 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 22:00:32:245 | RL | INFO | +0 | Main - System Specs: RocketLauncher Dir: F:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 32667.46 MB Free Memory: 27380.44 MB Used Memory: 5287.023 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: Intel(R) HD Graphics 630 GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 23.20.16.4849 GPU 2 Name: NVIDIA GeForce GTX 1080 GPU 2 RAM: -1.00 MB GPU 2 Driver Version: 25.21.14.1634 Sound 1 Device: Intel(R) Display Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: Realtek Audio Sound 3 Status: Enabled Sound 4 Device: NVIDIA High Definition Audio Sound 4 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: Yes RL Compatibility Flags: ~ RUNASADMIN Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 2560x1440 (2560x1400 work) [32bit] [59hz] [Landscape] (Primary) Current AHK Desktop Width: 2560 Current AHK Desktop Height: 1440 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 22:00:32:245 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\RocketLauncher.exe exists 22:00:32:245 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.2.0.1 LegalCopyright ©2016 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.2.0.1 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2195456 bytes Created: 10/3/2018 - 11:21:23 PM Modified: 10/3/2018 - 11:21:24 PM 22:00:32:245 | RL | INFO | +0 | Main - Raw CLI received: "-s MAME -r Killer Instinct -f F:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1" 22:00:32:245 | RL | TRACE | +0 | File.__New - Creating new file object of: "F:\RocketLauncher\Module Extensions\RocketLauncher.dll" 22:00:32:261 | RL | INFO | +15 | File.CheckFile - Checking if "F:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 22:00:32:261 | RL | TRACE | +0 | File.Exist - This file exists: F:\RocketLauncher\Module Extensions\RocketLauncher.dll 22:00:32:261 | RL | DEBUG | +0 | File.CheckFile - Attributes: FileDescription RocketLauncher Utils FileVersion 1.1.0.0 InternalName RocketLauncher.dll LegalCopyright Copyright © RocketLauncher 2013-2016 OriginalFilename RocketLauncher.dll ProductName RocketLauncher ProductVersion 1.1.0.0 File Size: 81408 bytes Created: 10/3/2018 - 11:32:17 PM Modified: 10/3/2018 - 11:32:18 PM 22:00:32:261 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\Array.ahk 22:00:32:261 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4926 bytes Created: 10/3/2018 - 11:21:23 PM Modified: 10/3/2018 - 11:21:23 PM 22:00:32:276 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\BinHexRW.ahk 22:00:32:276 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5112 bytes Created: 10/10/2016 - 2:25:10 AM Modified: 10/3/2018 - 6:15:42 PM 22:00:32:276 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\Module Extensions\BlockInput.exe exists 22:00:32:276 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:42 PM 22:00:32:292 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 22:00:32:292 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5503 bytes Created: 10/3/2018 - 11:32:12 PM Modified: 10/3/2018 - 11:32:12 PM 22:00:32:292 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 22:00:32:292 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:43 PM 22:00:32:308 | RL | ERROR | +16 | CRC Check - No CRC defined on the header for: F:\RocketLauncher\Module Extensions\gdip.ahk 22:00:32:308 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:44 PM 22:00:32:308 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\gdip_alt.ahk 22:00:32:308 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5955 bytes Created: 10/10/2016 - 2:25:22 AM Modified: 10/3/2018 - 6:15:44 PM 22:00:32:308 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\Module Extensions\gsdll32.dll exists 22:00:32:323 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 13090816 bytes Created: 3/5/2016 - 12:03:58 AM Modified: 10/3/2018 - 6:15:44 PM 22:00:32:323 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\Module Extensions\itextsharp.dll exists 22:00:32:323 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 3/5/2016 - 12:03:58 AM Modified: 10/3/2018 - 6:15:45 PM 22:00:32:339 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\Java.ahk 22:00:32:339 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 7859 bytes Created: 10/10/2016 - 2:25:36 AM Modified: 10/3/2018 - 6:15:45 PM 22:00:32:339 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\JSON.ahk 22:00:32:339 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9227 bytes Created: 3/9/2016 - 5:42:44 AM Modified: 10/3/2018 - 6:15:45 PM 22:00:32:339 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\Origin.ahk 22:00:32:354 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 4915 bytes Created: 10/10/2016 - 2:26:16 AM Modified: 10/3/2018 - 6:15:45 PM 22:00:32:354 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\RegRW64.ahk 22:00:32:354 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:45 PM 22:00:32:354 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\RIni.ahk | v1.7 22:00:32:371 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 67872 bytes Created: 9/11/2016 - 2:40:14 PM Modified: 10/3/2018 - 6:15:45 PM 22:00:32:372 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 22:00:32:380 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.5717.6837 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.5717.6837 CompanyName Markovtsev Vadim File Size: 167424 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:46 PM 22:00:32:385 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\Steam.ahk 22:00:32:386 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5517 bytes Created: 10/10/2016 - 2:26:24 AM Modified: 10/3/2018 - 6:15:46 PM 22:00:32:392 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\VA.ahk 22:00:32:393 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:46 PM 22:00:32:395 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\VA_Extension.ahk 22:00:32:395 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3862 bytes Created: 10/10/2016 - 2:26:32 AM Modified: 10/3/2018 - 6:15:46 PM 22:00:32:395 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\7z.ahk 22:00:32:395 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 33916 bytes Created: 10/3/2018 - 11:32:25 PM Modified: 10/3/2018 - 11:32:25 PM 22:00:32:411 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Bezel.ahk 22:00:32:411 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 121257 bytes Created: 10/3/2018 - 11:21:20 PM Modified: 10/3/2018 - 11:21:20 PM 22:00:32:411 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Fade.ahk 22:00:32:411 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 39707 bytes Created: 10/3/2018 - 11:32:06 PM Modified: 10/3/2018 - 11:32:07 PM 22:00:32:427 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Fade Init.ahk 22:00:32:429 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1140 bytes Created: 10/10/2016 - 2:27:46 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:433 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Fade Animations.ahk 22:00:32:433 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 77961 bytes Created: 10/10/2016 - 2:27:36 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:433 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Keymapper.ahk 22:00:32:433 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 33682 bytes Created: 10/10/2016 - 2:28:28 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:433 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Keymapper Init.ahk 22:00:32:433 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3966 bytes Created: 10/10/2016 - 2:28:16 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:449 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\MultiGame.ahk 22:00:32:449 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 41583 bytes Created: 10/10/2016 - 2:28:46 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:449 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\MultiGame Init.ahk 22:00:32:449 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 169 bytes Created: 10/10/2016 - 2:28:38 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:464 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\MultiPlayer.ahk 22:00:32:464 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 67277 bytes Created: 10/10/2016 - 2:28:54 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:464 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Pause.ahk 22:00:32:464 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 408415 bytes Created: 10/3/2018 - 11:32:19 PM Modified: 10/3/2018 - 11:32:19 PM 22:00:32:480 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Pause Init.ahk 22:00:32:480 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 563 bytes Created: 10/10/2016 - 2:29:14 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:480 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Password.ahk 22:00:32:480 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 10131 bytes Created: 10/10/2016 - 2:29:06 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:495 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk 22:00:32:495 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 31509 bytes Created: 10/3/2018 - 11:32:10 PM Modified: 10/3/2018 - 11:32:10 PM 22:00:32:495 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Log\Logger.ahk 22:00:32:495 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3558 bytes Created: 10/10/2016 - 2:32:18 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:495 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk 22:00:32:495 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 6709 bytes Created: 10/3/2018 - 11:32:06 PM Modified: 10/3/2018 - 11:32:06 PM 22:00:32:511 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk 22:00:32:511 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 2084 bytes Created: 10/3/2018 - 11:21:20 PM Modified: 10/3/2018 - 11:21:20 PM 22:00:32:511 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\ArrayUtils.ahk 22:00:32:511 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 306 bytes Created: 10/3/2018 - 11:32:16 PM Modified: 10/3/2018 - 11:32:16 PM 22:00:32:511 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\LocaleUtils.ahk 22:00:32:527 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 2104 bytes Created: 10/3/2018 - 11:21:25 PM Modified: 10/3/2018 - 11:21:25 PM 22:00:32:527 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk 22:00:32:527 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 7754 bytes Created: 10/3/2018 - 11:21:22 PM Modified: 10/3/2018 - 11:21:22 PM 22:00:32:527 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk 22:00:32:527 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 2948 bytes Created: 10/10/2016 - 2:33:56 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:542 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\ArchiveFile.ahk 22:00:32:542 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 346 bytes Created: 10/3/2018 - 11:21:22 PM Modified: 10/3/2018 - 11:21:23 PM 22:00:32:542 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\DemulShooter.ahk 22:00:32:542 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 786 bytes Created: 10/3/2018 - 11:21:22 PM Modified: 10/3/2018 - 11:21:22 PM 22:00:32:542 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk 22:00:32:542 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1231 bytes Created: 10/10/2016 - 2:34:30 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:558 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\File.ahk 22:00:32:558 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9522 bytes Created: 10/3/2018 - 11:32:05 PM Modified: 10/3/2018 - 11:32:05 PM 22:00:32:558 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\FileUtils.ahk 22:00:32:558 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 339 bytes Created: 10/3/2018 - 11:32:14 PM Modified: 10/3/2018 - 11:32:15 PM 22:00:32:558 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk 22:00:32:573 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 643 bytes Created: 10/10/2016 - 2:34:48 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:573 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk 22:00:32:573 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4364 bytes Created: 10/10/2016 - 2:34:56 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:573 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\Process.ahk 22:00:32:573 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9711 bytes Created: 10/3/2018 - 11:32:26 PM Modified: 10/3/2018 - 11:32:26 PM 22:00:32:589 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\PropertiesFile.ahk 22:00:32:589 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4218 bytes Created: 10/3/2018 - 11:32:09 PM Modified: 10/3/2018 - 11:32:09 PM 22:00:32:589 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk 22:00:32:589 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3898 bytes Created: 10/10/2016 - 2:35:14 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:589 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\XMLFile.ahk 22:00:32:589 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 331 bytes Created: 10/3/2018 - 11:32:04 PM Modified: 10/3/2018 - 11:32:04 PM 22:00:32:605 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk 22:00:32:605 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5426 bytes Created: 10/10/2016 - 2:35:22 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:605 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk 22:00:32:605 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4603 bytes Created: 10/10/2016 - 2:35:32 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:620 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk 22:00:32:620 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 24655 bytes Created: 10/3/2018 - 11:32:10 PM Modified: 10/3/2018 - 11:32:10 PM 22:00:32:620 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk 22:00:32:620 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1171 bytes Created: 10/10/2016 - 2:35:48 AM Modified: 10/3/2018 - 6:15:34 PM 22:00:32:620 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk 22:00:32:620 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 72279 bytes Created: 10/10/2016 - 2:29:32 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:636 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Shader.ahk 22:00:32:636 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4183 bytes Created: 10/10/2016 - 2:29:50 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:636 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Shader Init.ahk 22:00:32:636 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 412 bytes Created: 10/10/2016 - 2:29:40 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:652 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Shared.ahk 22:00:32:652 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 173248 bytes Created: 10/3/2018 - 11:32:18 PM Modified: 10/3/2018 - 11:32:18 PM 22:00:32:652 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Statistics.ahk 22:00:32:652 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 27008 bytes Created: 10/10/2016 - 2:30:22 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:667 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Statistics Init.ahk 22:00:32:667 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 43 bytes Created: 10/10/2016 - 2:30:14 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:667 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Virtual Drive.ahk 22:00:32:667 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 20294 bytes Created: 10/10/2016 - 2:30:46 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:667 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\XHotkey.ahk 22:00:32:683 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 26615 bytes Created: 10/10/2016 - 2:31:04 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:683 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\XHotkey Init.ahk 22:00:32:683 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1073 bytes Created: 10/10/2016 - 2:30:56 AM Modified: 10/3/2018 - 6:15:33 PM 22:00:32:683 | RL | DEBUG | +0 | Main - Received this dbName with no path via CLI: "Killer Instinct" 22:00:32:683 | RL | DEBUG | +0 | Main - dbName: Killer Instinct 22:00:32:683 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 22:00:32:683 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Plugins\HyperSpin.plugin 22:00:32:683 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9590 bytes Created: 10/3/2018 - 11:21:20 PM Modified: 10/3/2018 - 11:21:20 PM 22:00:32:698 | RL | TRACE | +16 | Process.__New - Creating new process object for: "F:\HyperSpin\HyperSpin.exe" 22:00:32:698 | RL | TRACE | +0 | File.__New - Creating new file object of: "F:\HyperSpin\HyperSpin.exe" 22:00:32:698 | RL | INFO | +0 | Main - RocketLauncher received "MAME" and "Killer Instinct" 22:00:32:698 | RL | INFO | +0 | Main - Killer Instinct contains a System key in F:\RocketLauncher\Settings\MAME\Games.ini. Switching systemName to MAME 22:00:32:698 | RL | INFO | +0 | Main - Did not find a "F:\RocketLauncher\Settings\MAME\Game Options.ini" file, skipping any game-specific options. 22:00:32:698 | RL | INFO | +0 | Main - Killer Instinct is switching to emulator PCLauncher via: F:\RocketLauncher\Settings\MAME\Games.ini 22:00:32:698 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in F:\RocketLauncher\Settings\MAME\Emulators.ini 22:00:32:698 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in F:\RocketLauncher\Settings\Global Emulators.ini 22:00:32:698 | RL | INFO | +0 | Main - Found [PCLauncher] in F:\RocketLauncher\Settings\Global Emulators.ini 22:00:32:714 | RL | INFO | +15 | CheckFile - Checking if F:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk exists 22:00:32:714 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 20197 bytes Created: 10/13/2016 - 5:13:50 AM Modified: 10/3/2018 - 6:15:57 PM 22:00:32:714 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 22:00:32:714 | RL | INFO | +0 | Main - Killer Instinct will use module: F:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk 22:00:32:761 | RL | INFO | +47 | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher". 22:00:32:761 | RL | INFO | +0 | Main - INI Keys read 22:00:32:777 | RL | INFO | +16 | CheckFile - Checking if F:\RocketLauncher\Module Extensions\7z.exe exists 22:00:32:777 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 262144 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:42 PM 22:00:32:777 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\Module Extensions\7z.dll exists 22:00:32:777 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription 7z Plugin FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.dll ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 1012224 bytes Created: 3/5/2016 - 12:03:56 AM Modified: 10/3/2018 - 6:15:42 PM 22:00:32:792 | RL | INFO | +15 | Main - "Killer Instinct" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 22:00:32:792 | RL | INFO | +0 | CheckPaths - Started 22:00:32:792 | RL | DEBUG | +0 | CheckPaths - Current romName: 22:00:32:792 | RL | DEBUG | +0 | CheckPaths - Current romPath: F:\HyperSpin\Emulators\MAME\roms 22:00:32:792 | RL | DEBUG | +0 | CheckPaths - Current romExtension: 22:00:32:792 | RL | INFO | +0 | CheckPaths - Ended 22:00:32:792 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event Global RLLog Global RLObject 0 := "12" rlPath := "F:\RocketLauncher" pluginPath := "F:\RocketLauncher\Plugins" pluginName := "HyperSpin" pluginExt := ".plugin" contextOnExit := "1" rlMode := "" rlTitle := "RocketLauncher" rlVersion := "1.2.0.1" rlAuthor := "djvj" rlURL := "www.rlauncher.com" langFile := "F:\RocketLauncher\Data\Language\Localization.ini" primMonitor := "1" frontendPID := "" frontendPath := "F:\HyperSpin" frontendExe := "HyperSpin.exe" frontendExt := "exe" frontendName := "HyperSpin" frontendDrive := "F" exitEmulatorKey := "~Esc" restoreFE := "false" exitScriptKey := "~q & ~s" toggleCursorKey := "~e & ~t" emuFullPath := "" emuPath := "" emuName := "PCLauncher" emuExt := "" baseRomPath := "" romPath := "F:\HyperSpin\Emulators\MAME\roms" romPathFromIni := "F:\HyperSpin\Emulators\MAME\roms" romExtension := "" romExtensionOrig := "" romExtensions := "" executable := "" systemDbName := "MAME" systemName := "MAME" dbPath := "" dbName := "Killer Instinct" dbExt := "" romFoundByExt := "" romName := "" romMapPath := "" romMappingEnabled := "false" romMappingLaunchMenuEnabled := "false" romMappingFirstMatchingExt := "false" romMappingShowAllRomsInArchive := "true" romMappingNumberOfGamesByScreen := "7" romMappingHideParent := "false" romMappingMenuWidth := "400" romMappingMenuMargin := "65" romMappingTextFont := "Bebas Neue" romMappingTextOptions := "cFFFFFFFF r4 s60 Bold" romMappingDisabledTextColor := "ff888888" romMappingTextSizeDifference := "7" romMappingTextMargin := "15" romMappingTitleTextFont := "Bebas Neue" romMappingTitleTextOptions := "cFFFFFFFF r4 s90 Bold" romMappingTitle2TextFont := "Bebas Neue" romMappingTitle2TextOptions := "cFFFFFFFF r4 s22 Bold" romMappingGameInfoTextFont := "Bebas Neue" romMappingGameInfoTextOptions := "cFFFFFFFF r4 s22 Regular" romMappingGameNameTextFont := "Bebas Neue" romMappingGameNameTextOptions := "cFFFFFFFF r4 s40 Regular" romMappingBackgroundBrush := "aa000000" romMappingColumnBrush := "33000000" romMappingButtonBrush1 := "6f000000" romMappingButtonBrush2 := "33000000" romMappingBackgroundAlign := "Stretch and Lose Aspect" romMappingMenuFlagWidth := "55" romMappingMenuFlagSeparation := "7" romMappingDefaultMenuList := "FullList" romMappingSingleFilteredRomAutomaticLaunch := "false" altArchiveNameOnly := "" altRomNameOnly := "" altArchiveAndRomName := "" altArchiveAndManyRomNames := "" altRomNamesOnly := "" romMapScenario := "" skipchecks := "false" romMatchExt := "false" blockInputTime := "0" blockInputFile := "F:\RocketLauncher\Module Extensions\BlockInput.exe" errorLevelReporting := "false" lockLaunch := "false" lockLaunchGame := "" screenRotationAngle := "0" screenRotationAngleGame := "" setResolution := "" logFile := "" logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel := "10" logShowDebugConsole := "false" logShowCommandWindow := "false" logCommandWindow := "false" logIncludeModule := "true" logIncludeFileProperties := "true" logIncludeDLLLogs := "false" errorSounds := "true" rlDebugConsoleStdout := "" sysLang := "English_United_States" sysType := "64-bit" broadcastWindowTitle := "" navUpKey := "Up" navDownKey := "Down" navLeftKey := "Left" navRightKey := "Right" navSelectKey := "Enter" navP2UpKey := "Numpad8" navP2DownKey := "Numpad2" navP2LeftKey := "Numpad4" navP2RightKey := "Numpad6" navP2SelectKey := "NumpadEnter" originalWidth := "2560" originalHeight := "1440" vdEnabled := "false" vdFullPath := "" vdUseSCSI := "true" vdDriveLetter := "" vdDriveLetterScsi := "" vdAddDrive := "true" demulShooterPath := "" servoStikEnabled := "false" servoStikExitMode := "false" ledblinkyEnabled := "false" ledblinkySystemName := "" ledblinkyFullPath := "" ledblinkyProfilePath := "F:\RocketLauncher\Profiles\LEDBlinky" ledblinkyRLProfile := "F:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher" winIPACFullPath := "" ultraMapEnabled := "false" ultraMapFullPath := "" emuIdleShutdown := "0" launchPasswordHash := "UpUpDownDownLeftRightLeftRight" cursorSize := "" hideCursor := "false" hideEmu := "false" hideFE := "false" suspendFE := "false" fadeIn := "false" fadeInDuration := "500" fadeInTransitionAnimation := "DefaultAnimateFadeIn" fadeInDelay := "0" fadeInExitDelay := "0" fadeOutExitDelay := "0" fadeOut := "false" fadeOutExtraScreen := "false" fadeOutDuration := "500" fadeOutTransitionAnimation := "DefaultAnimateFadeOut" fadeOutDelay := "0" fadeLyrInterpolation := "7" fadeMuteEmulator := "false" fadeUseBackgrounds := "false" fadeClickThrough := "false" fadeSounds := "true" fade7zProgressMode := "extraction" fadeWidthBaseRes := "1920" fadeHeightBaseRes := "1080" fadeLyr1Color := "FF000000" fadeLyr1AlignImage := "Stretch and Lose Aspect" fadeLyr2Pos := "Stretch and Lose Aspect" fadeLyr2X := "0" fadeLyr2Y := "0" fadeLyr2W := "" fadeLyr2H := "" fadeLyr2Adjust := "1" fadeLyr2PicPad := "0" fadeLyr2Prefix := "Extra Layer 1 - Console" fadeLyr3Pos := "Center" fadeLyr3X := "450" fadeLyr3Y := "450" fadeLyr3W := "" fadeLyr3H := "" fadeLyr3Adjust := "1" fadeLyr3PicPad := "0" fadeLyr3Speed := "750" fadeLyr3Animation := "DefaultFadeAnimation" fadeLyr37zAnimation := "DefaultFadeAnimation" fadeLyr3Type := "imageandbar" fadeLyr3ImgFollow7zProgress := "true" fadeLyr3Repeat := "1" fadeLyr3BackImageTransparency := "30" fadeLyr3StaticPos := "No Alignment" fadeLyr3StaticX := "0" fadeLyr3StaticY := "870|1575" fadeLyr3StaticW := "" fadeLyr3StaticH := "" fadeLyr3StaticAdjust := "1" fadeLyr3StaticPicPad := "0" fadeLyr3StaticPrefix := "Info Bar" fadeLyr4Adjust := "1" fadeLyr4X := "1792|952" fadeLyr4Y := "891|1596" fadeLyr4W := "128" fadeLyr4H := "" fadeLyr4Pos := "No Alignment" fadeLyr4FPS := "50" fadeLyr4PicPad := "0" fadeTranspGifColor := "FFFFFF" fadeBarWindow := "Image" fadeBarWindowX := "" fadeBarWindowY := "" fadeBarWindowW := "900" fadeBarWindowH := "" fadeBarWindowR := "30" fadeBarWindowM := "30" fadeBarWindowHatchStyle := "8" fadeBar := "7zOnly" fadeProgressDuration := "0" fadeBarBack := "true" fadeBarBackColor := "FF555555" fadeBarH := "30" fadeBarR := "10" fadeBarColor := "DD00BFFF" fadeBarHatchStyle := "8" fadeBarPercentageText := "true" fadeBarInfoText := "true" fadeBarXOffset := "0" fadeBarYOffset := "150" fadeRomInfoDescription := "filtered text" fadeRomInfoSystemName := "image" fadeRomInfoYear := "text with label" fadeRomInfoDeveloper := "disabled" fadeRomInfoPublisher := "disabled" fadeRomInfoGenre := "disabled" fadeRomInfoRating := "image" fadeRomInfoOrder := "Description|SystemName|Year|Developer|Genre|Rating|Publisher" fadeRomInfoTextPlacement := "User Defined" fadeRomInfoTextMargin := "7" fadeRomInfoText1Options := "w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular" fadeRomInfoText2Options := "w400 x8 y15 cFF555555 r4 s60 Bold" fadeRomInfoText3Options := "w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular" fadeRomInfoText4Options := "w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular" fadeRomInfoText5Options := "cFF555555 r4 s42 Bold" fadeRomInfoText6Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular" fadeRomInfoText7Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular" fadeStats_Number_of_Times_Played := "text with label" fadeStats_Last_Time_Played := "text with label" fadeStats_Average_Time_Played := "text with label" fadeStats_Total_Time_Played := "text with label" fadeStats_System_Total_Played_Time := "text with label" fadeStats_Total_Global_Played_Time := "text with label" fadeStatsInfoOrder := "Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time" fadeStatsInfoTextPlacement := "topRight" fadeStatsInfoTextMargin := "7" fadeStatsInfoText1Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText2Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText3Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText4Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText5Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText6Options := "cFFB4B4B4 r4 s22 Bold" fadeText1X := "0" fadeText1Y := "0" fadeText1Options := "cFFB4B4B4 r4 s30 Right Bold" fadeText1 := "Loading Game" fadeText2X := "0" fadeText2Y := "0" fadeText2Options := "cFFB4B4B4 r4 s30 Right Bold" fadeText2 := "Extraction Complete, Ready" fadeText3 := "Loading Game" fadeText4 := "Loading Complete" fadeFont := "Bebas Neue" fadeSystemAndRomLayersOnly := "false" fadeExtractionTime := "disabled" fadeExtractionTimeTextX := "0" fadeExtractionTimeTextY := "0" fadeExtractionTimeTextOptions := "cFF555555 r4 s20 Bold" fadeInterruptKey := "" detectFadeErrorEnabled := "true" fadeImgPath := "F:\RocketLauncher\Media\Fade" RLDataPath := "F:\RocketLauncher\Data" RLMediaPath := "F:\RocketLauncher\Media" RLErrSoundPath := "F:\RocketLauncher\Media\Sounds\Error" modulesPath := "F:\RocketLauncher\Modules" moduleFullName := "F:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk" moduleName := "PCLauncher" modulePath := "F:\RocketLauncher\Modules\PCLauncher" moduleExtension := "ahk" moduleExtensionsPath := "F:\RocketLauncher\Module Extensions" libPath := "F:\RocketLauncher\Lib" sevenZEnabled := "false" sevenZPath := "F:\RocketLauncher\Module Extensions\7z.exe" sevenZDllPath := "F:\RocketLauncher\Module Extensions\7z.dll" sevenZExtractPath := "F:\RocketLauncher Temp" sevenZExtractPathOrig := "" sevenZAttachSystemName := "false" sevenZDelTemp := "true" sevenZFormats := ".zip|.rar|.7z|.lha|.lzh|.gzip|.tar" sevenZFormatsNoP := "zip|rar|7z|lha|lzh|gzip|tar" sevenZFormatsRegEx := "\.zip|\.rar|\.7z|\.lha|\.lzh|\.gzip|\.tar" sevenZGamesToKeep := "" sevenZDeletePerSystem := "false" sevenZExtensions := "zip|rar|7z|lha|lzh|gzip|tar" 7zExtractPath := "F:\RocketLauncher Temp" mgEnabled := "false" mgKey := "~NumpadSub" mgBackgroundColor := "FF000000" mgSidePadding := "0.2" mgWidthBaseRes := "1920" mgHeightBaseRes := "1080" mgYOffset := "500|800" mgFont := "Arial" mgText1Options := "x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic" mgText1Text := "Please select a game" mgText2Options := "w96p cFFFFFFFF r4 s50 Center BoldItalic" mgText2Offset := "100" mgUseSound := "true" mgSoundfreq := "300" mgExitEffect := "none" mgSelectedEffect := "rotate" mgUseGameArt := "false" mgCandidate := "" mgValidTypes := "\(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side" mgOnLaunch := "false" pauseEnabled := "false" pauseKey := "~NumpadAdd" pauseBackToMenuBarKey := "X" pauseZoomInKey := "C" pauseZoomOutKey := "V" pauseScreenshotKey := "~PrintScreen" pauseHiToTextPath := "F:\RocketLauncher\Module Extensions\HiToText.exe" pauseSaveStateKeyCodes := "" pauseLoadStateKeyCodes := "" keyboardEncoder := "" keyboardEncoderEnabled := "false" keymapperEnabled := "false" keymapperAHKMethod := "false" keymapper := "xpadder" xpadderFullPath := "F:\Utilities\Xpadder\xpadder.exe" joyToKeyFullPath := "F:\Utilities\JoyToKey\JoyToKey.exe" profilePath := "F:\RocketLauncher\Profiles" keymapperProfilePath := "F:\RocketLauncher\Profiles\xpadder" keymapperFrontEndProfileName := "RocketLauncherUI" keymapperFrontEndProfile := "false" keymapperRocketLauncherProfileEnabled := "false" joyIDsEnabled := "false" joyIDsPreferredControllersGlobal := "" joyIDsPreferredControllersSystem := "use_global" joyIDsPreferredControllersOnExit := "" CustomJoyNamesEnabled := "false" CustomJoyNames := "" rotateMethod := "false" FEProfile := "F:\RocketLauncher\Profiles\xpadder\RocketLauncherUI" defaultProfile := "F:\RocketLauncher\Profiles\xpadder\_Default" systemProfile := "F:\RocketLauncher\Profiles\xpadder\MAME" xPadderSystemProfile := "F:\RocketLauncher\Profiles\xpadder\MAME\_Default" emuProfile := "F:\RocketLauncher\Profiles\xpadder\MAME\PCLauncher" romProfile := "F:\RocketLauncher\Profiles\xpadder\MAME\Killer Instinct" RocketLauncherProfile := "F:\RocketLauncher\Profiles\xpadder\RocketLauncher" blankProfile := "F:\RocketLauncher\Profiles\xpadder\_Default\blank" ahkFEProfile := "F:\RocketLauncher\Profiles\AHK\RocketLauncherUI" ahkDefaultProfile := "F:\RocketLauncher\Profiles\AHK\_Default" ahkSystemProfile := "F:\RocketLauncher\Profiles\AHK\MAME" ahkEmuProfile := "F:\RocketLauncher\Profiles\AHK\MAME\PCLauncher" ahkRomProfile := "F:\RocketLauncher\Profiles\AHK\MAME\Killer Instinct" ahkRocketLauncherProfile := "F:\RocketLauncher\Profiles\AHK\RocketLauncher" bezelEnabled := "false" bezelICEnabled := "false" shaderName := "false" shaderColor := "" shaderTransparency := "" statisticsEnabled := "true" pressDuration := "-1" emuVolume := "1" dxwndIni := "F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini" dxwndFullPath := "F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe" qResFullPath := "F:\RocketLauncher\Module Extensions\QRes.exe" mon1O := "" pacDrivedllFile := "F:\RocketLauncher\Module Extensions\PacDrive32.dll" userFadeAnimIniFile := "F:\RocketLauncher\Lib\User Fade Animations.ini" testFile := "" testDuration := "" initialErrorMode := "0" 22:00:32:792 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 22:00:32:792 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 22:00:32:792 | RL | DEBUG | +0 | BuildScript - Module starts on line: 2 22:00:32:792 | RL | INFO | +0 | BuildScript - Validating module 22:00:32:792 | RL | INFO | +0 | BuildScript - Validation complete 22:00:32:792 | RL | INFO | +0 | BuildScript - Module: MEmu := "PCLauncher" MEmuV := "N/A" MURL := ["http://www.rlauncher.com/wiki/index.php?title=PCLauncher"] MAuthor := ["djvj"] MVersion := "2.2.7" MCRC := "5814E2E" iCRC := "28F444EF" MID := "635243126483565041" MSystem := ["American Laser Games","Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Singstar","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project","Ultrastar","Ultrastar Deluxe","Windows Games"] ;---------------------------------------------------------------------------- ; Notes: ; Use the examples in the ini, in your Modules\PCLauncher\ folder, to add more applications. ; PCLauncher supports per-System inis. Copy your PCLauncher ini in the same folder and rename it to match the System's Name. Use this if you have games with the same name across multiple systems. ; Read the tooltips for each module setting in RocketLauncherUI for the definitions of each key and help using them. ; For information on how to use this module and what all the settings do, please see http://www.rlauncher.com/wiki/index.php?title=PCLauncher ;---------------------------------------------------------------------------- StartModule() moduleIni.CheckFile("Could not find """ . moduleIni.FileFullPath . """`n`nRocketLauncherUI will create this file when you configure your first game to be used with the " . MEmu . " module.") Application := moduleIni.Read(dbName, "Application",,,1) AppWaitExe := moduleIni.Read(dbName, "AppWaitExe",,,1) DiscImage := moduleIni.Read(dbName, "DiscImage",,,1) DXWndGame := moduleIni.Read(dbName, "DXWndGame",,,1) DXWndMaximizeWindow := moduleIni.Read(dbName, "DXWndMaximizeWindow",,,1) ExitMethod := moduleIni.Read(dbName, "ExitMethod",,,1) FadeTitle := moduleIni.Read(dbName, "FadeTitle",,,1) FadeTitleWaitTillActive := moduleIni.Read(dbName, "FadeTitleWaitTillActive","true",,1) FadeTitleTimeout := moduleIni.Read(dbName, "FadeTitleTimeout",,,1) FadeInExitSleep := moduleIni.Read(dbName, "FadeInExitSleep",,,1) HideConsole := moduleIni.Read(dbName, "HideConsole",,,1) OriginGame := moduleIni.Read(dbName, "OriginGame",,,1) Parameters := moduleIni.Read(dbName, "Parameters",,,1) PostLaunch := moduleIni.Read(dbName, "PostLaunch",,,1) PostLaunchParameters := moduleIni.Read(dbName, "PostLaunchParameters",,,1) PostLaunchSleep := moduleIni.Read(dbName, "PostLaunchSleep",,,1) PostExit := moduleIni.Read(dbName, "PostExit",,,1) PostExitParameters := moduleIni.Read(dbName, "PostExitParameters",,,1) PostExitSleep := moduleIni.Read(dbName, "PostExitSleep",,,1) PreLaunch := moduleIni.Read(dbName, "PreLaunch",,,1) PreLaunchParameters := moduleIni.Read(dbName, "PreLaunchParameters",,,1) PreLaunchMode := moduleIni.Read(dbName, "PreLaunchMode",,,1) PreLaunchSleep := moduleIni.Read(dbName, "PreLaunchSleep",,,1) SteamID := moduleIni.Read(dbName, "SteamID",,,1) WorkingFolder := moduleIni.Read(dbName, "WorkingFolder",,,1) bezelTopOffset := moduleIni.Read(dbName, "BezelTopOffset","0",,1) bezelBottomOffset := moduleIni.Read(dbName, "BezelBottomOffset","0",,1) bezelLeftOffset := moduleIni.Read(dbName, "BezelLeftOffset","0",,1) bezelRightOffset := moduleIni.Read(dbName, "BezelRightOffset","0",,1) BezelFixedResMode := moduleIni.Read(dbName, "BezelFixedResMode","false",,1) HideWindowTitleBar := moduleIni.Read(dbName, "HideWindowTitleBar","true",,1) HideWindowBorder := moduleIni.Read(dbName, "HideWindowBorder","true",,1) HideWindowMenuBar := moduleIni.Read(dbName, "HideWindowMenuBar","true",,1) HideDecoratorsAfterMove := moduleIni.Read(dbName, "HideDecoratorsAfterWindowMove","false",,1) HideWindowBorderFirst := moduleIni.Read(dbName, "HideWindowBorderFirst","false",,1) Fullscreen := moduleIni.Read(dbName, "Fullscreen",,,1) If (!Application && !SteamID) { ; This app cannot be launched if no info exists already in the ini and this is not a steam game ScriptError("You have not set up " . dbName . " in RocketLauncherUI yet, so PCLauncher does not know what exe, FadeTitle, and/or SteamID to watch for.") } ; Configuring bezel settings that would normally be set in BezelLabel If (HideWindowTitleBar = "false") disableHideTitleBar := true If (HideWindowBorder = "false") disableHideBorder := true If (HideWindowMenuBar = "false") disableHideToggleMenu := true If (HideDecoratorsAfterMove = "true") hideDecoratorsAfterWindowMove := true If (HideWindowBorderFirst = "true") hideBorderFirst := true If Fullscreen { ;Warn user if fullscreen is set, but no custom game user function file exists for this game gameUserFunc := new File(libPath . "\Lib\User Functions\" . systemName . "\" . dbName . ".ahk") If (!gameUserFunc.Exist()) { RLLog.Warning("PCLauncher - You have configured a fullscreen setting for this game, but no GameUserFunction file exists at '" . gameUserFunc.FileFullPath . "' therefore the fullscreen setting won't have any effect until you create such file and implement the proper SetFullscreen function") } } BezelGUI() FadeInStart() If (BezelFixedResMode = "true") BezelStart("fixResMode") Else BezelStart() If Application { primaryExe := new Emulator(Application) ; instantiate primary application executable object } If (AppWaitExe != "") { AppWaitExe := new Process(AppWaitExe) } If FadeTitle { FadeTitleObj := StringUtils.ParsePCTitle(FadeTitle) appPrimaryWindow := new Window(new WindowTitle(FadeTitleObj.Title,FadeTitleObj.Class)) ; instantiate primary application window object } ; If Application needs a cd/dvd image in the drive, mount it in DT first If DiscImage { RLLog.Info("PCLauncher - Application is a Disc Image, mounting it in DT") appIsImage := 1 DiscImage := new File(GetFullName(DiscImage)) ; convert a relative path defined in the PCLauncher ini to absolute DiscImage.CheckFile("Cannot find this DiscImage for " . dbName . ":`n" . DiscImage.FileFullPath) ; StringUtils.SplitPath(DiscImage,"",ImagePath,ImageExt,ImageName) If StringUtils.Contains(DiscImage.FileExt,"mds|mdx|b5t|b6t|bwt|ccd|cue|isz|nrg|cdi|iso|ape|flac") { VirtualDrive("get") ; get the vdDriveLetter ; VirtualDrive("mount",ImagePath . "\" . ImageName . "." . ImageExt) VirtualDrive("mount",DiscImage.FileFullPath) } Else ScriptError("You defined a DiscImage, but it is not a supported format for this module and/or DT:`nccd,cdi,cue,iso,isz,nrg") } ; Verify module's settings are set CheckSettings() If PreLaunch { RLLog.Info("PCLauncher - PreLaunch set by user, running: " . PreLaunch) PreLaunchParameters := If (!PreLaunchParameters or PreLaunchParameters="ERROR") ? "" : PreLaunchParameters If (preLaunchMode = "run") { errLevel := PreLaunchExe.Run(If PreLaunchIsURL ? "" : PreLaunchParameters,,,,,(If PreLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") TimerUtils.Sleep(PreLaunchSleep) } Else { errLevel := PreLaunchExe.RunWait(If PreLaunchIsURL ? "" : PreLaunchParameters,,(If PreLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") } } If (DXWndGame = "true") ; start dxwnd if needed DxwndRun() Fullscreen := If BezelEnabled() ? "false" : Fullscreen FullscreenParams := CustomFunction.SetFullscreenPreLaunch(Fullscreen) If (FullscreenParams) { RLLog.Debug("PCLauncher - Setting fullscreen parameters to : " . FullscreenParams) Parameters .= " " . FullscreenParams } If StringUtils.Contains(mode,"steam|steambp") ; steam launch Steam(SteamID, primaryExe.FileFullPath, Parameters) Else If (mode = "origin") ; origin launch Origin(primaryExe.FileName, primaryExe.FilePath, Parameters) Else { If (mode = "url") { RLLog.Info("PCLauncher - Launching URL.") errLevel := primaryExe.Run() } Else { ; standard launch RLLog.Info("PCLauncher - Launching a standard application.") If (HideConsole = "true" and primaryExe.FileExt = "bat") { RLLog.Info("PCLauncher - Hiding DOS console for bat file.") objShell := ComObjCreate("WScript.Shell") objShell.CurrentDirectory := If WorkingFolder ? WorkingFolder : primaryExe.FilePath errLevel := objShell.Run("""" . primaryExe.FileName . """ " . Parameters, 0, false) } Else errLevel := primaryExe.Run(Parameters,,,,,1,If WorkingFolder ? WorkingFolder : "") } If errLevel ScriptError("There was a problem launching your " . (If appIsImage ? "ImageExe" : "Application") . ". Please check it is a valid executable.") } If PostLaunch { RLLog.Info("PCLauncher - PostLaunch set by user, running: " . PostLaunch) PostLaunchExe := new Process(PostLaunch) PostLaunchParameters := If (!PostLaunchParameters or PostLaunchParameters="ERROR") ? "" : PostLaunchParameters errLevel := PostLaunchExe.Run(If PostLaunchIsURL ? "" : PostLaunchParameters,,,,,(If PostLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PostLaunch application. Please check it is a valid executable.") TimerUtils.Sleep(PostLaunchSleep) } If FadeTitle { RLLog.Info("PCLauncher - FadeTitle set by user, waiting for """ . appPrimaryWindow.WinTitle.GetWindowTitle() . """") If (FadeTitleTimeout) appPrimaryWindow.Wait(FadeTitleTimeout) Else appPrimaryWindow.Wait() If (FadeTitleWaitTillActive = "true") appPrimaryWindow.WaitActive() } Else If AppWaitExe { RLLog.Info("PCLauncher - FadeTitle not set by user, but AppWaitExe is. Waiting for AppWaitExe: " . AppWaitExe.FileName) AppWaitExe.Process("Wait",15) If (AppWaitExe.PID = 0) ScriptError("PCLauncher - There was an error getting the Process ID of your AppWaitExe """ . AppWaitExe.FileName . """. Please try setting a FadeTitle instead.") } Else If SteamIDExe { RLLog.Info("PCLauncher - FadeTitle and AppWaitExe not set by user, but SteamIDExe was found. Waiting for SteamIDExe: " . SteamIDExe.FileFullPath) SteamIDExe.Process("Wait",15) ; wait 15 seconds for this process to launch If (SteamIDExe.PID = 0) ScriptError("PCLauncher - There was an error getting the Process ID from your SteamIDExe for """ . dbName . """. Please try setting a FadeTitle instead.") } Else If primaryExe.PID { RLLog.Info("PCLauncher - FadeTitle and AppWaitExe not set by user, but a PID for the primary application was found. Waiting for PID: " . primaryExe.PID) appPrimaryWindow.PID := primaryExe.PID ; store the PID of the primary exe into the window object appPrimaryWindow.Wait(,primaryExe.PID) ; only wait for the pid, not any other window element appPrimaryWindow.WaitActive(,primaryExe.PID) } Else RLLog.Error("PCLauncher - FadeTitle and AppWaitExe not set by user and no AppPID found from an Application, PCLauncher has nothing to wait for") If (DXWndGame = "true" and (DXWndMaximizeWindow = "aspect" or DXWndMaximizeWindow = "stretch")) appPrimaryWindow.Maximize(If (DXWndMaximizeWindow="aspect") ? "true" : "false") BezelDraw() TimerUtils.Sleep(FadeInExitSleep) ; PCLauncher setting for some stubborn games that keeps the fadeIn screen up a little longer FadeInExit() If AppWaitExe { If !FadeTitle { RLLog.Info("PCLauncher - Creating a window based on the AppWaitExe because FadeTitle was not set") appPrimaryWindow := new Window(new WindowTitle(,,,,AppWaitExe.PID)) ; instantiate AppWaitExe window object appPrimaryWindow.Wait() appPrimaryWindow.Get("ID") appPrimaryWindow.WinTitle.PID := "" ; remove PID from future window matches appPrimaryWindow.WinTitle.ID := appPrimaryWindow.ID ; inject hwnd ID so future matches use it instead } RLLog.Info("PCLauncher - Waiting for AppWaitExe """ . AppWaitExe.FileName . """ to close.") AppWaitExe.Process("WaitClose") } Else If FadeTitle { ; If fadeTitle is set and no appPID was created. RLLog.Info("PCLauncher - Waiting for FadeTitle """ . appPrimaryWindow.WinTitle.GetWindowTitle() . """ to close.") appPrimaryWindow.WaitClose() } Else If SteamIDExe { RLLog.Info("PCLauncher - Waiting for SteamIDExe """ . SteamIDExe.FileName . """ to close.") SteamIDExe.Process("WaitClose") } Else If primaryExe.PID { If !FadeTitle { RLLog.Info("PCLauncher - Creating a window based on the Primary Application """ . primaryExe.FileName . """ because FadeTitle nor AppWaitExe were set") appPrimaryWindow := new Window(new WindowTitle(,,,,primaryExe.PID)) ; instantiate primary application window object appPrimaryWindow.Wait() appPrimaryWindow.Get("ID") appPrimaryWindow.WinTitle.PID := "" ; remove PID from future window matches appPrimaryWindow.WinTitle.ID := appPrimaryWindow.ID ; inject hwnd ID so future matches use it instead } RLLog.Info("PCLauncher - Waiting for the Primary Application PID """ . primaryExe.PID . """ to close.") primaryExe.Process("WaitClose") } Else ScriptError("Could not find a proper AppWaitExe`, FadeTitle`, or AppPID (from the launched Application). Try setting either an AppWaitExe or FadeTitle so the module has something to look for.") If PostExit { RLLog.Info("PCLauncher - PostExit set by user, running: " . PostExit) PostExitExe := new Process(PostExit) PostExitParameters := If (!PostExitParameters or PostExitParameters="ERROR") ? "" : PostExitParameters errLevel := PostExitExe.Run(If PostExitIsURL ? "" : PostExitParameters,,,,,(If PostExitIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PostExit application. Please check it is a valid executable.") TimerUtils.Sleep(PostExitSleep) } ; If Application is a cd/dvd image, unmount it in DT If appIsImage VirtualDrive("unmount") ; Close steam if it was not open prior to launch, not really needed anymore because module knows how to launch if steam already running now ; If (primaryExe.PID = 0) ; Run, Steam.exe -shutdown, %SteamPath% ; close steam If (DXWndGame = "true") DxwndClose() BezelExit() FadeOutExit() ExitModule() CheckSettings() { Global Application,primaryExe Global PreLaunch,PreLaunchExe,PreLaunchIsURL Global PostLaunch,PostLaunchExe,PostLaunchIsURL Global PostExit,PostExitExe,PostExitIsURL Global moduleName,appIsImage,vdDriveLetter,SteamID,OriginGame,DXWndGame,mode,AppWaitExe,SteamIDExe,FadeTitle Global modulePath,fadeIn RLLog.Info("CheckSettings - Started") ; These checks allow you to run URL and Steam browser protocol commands. Without them ahk would error out that it can't find the file. This is different than setting a SteamID but either work If (SteamID) { mode := "steam" ; setting module to use steam mode RLLog.Info("PCLauncher - SteamID is set, setting mode to: """ . mode . """") } Else If (StringUtils.SubStr(Application,1,3) = "ste") { mode := "steambp" ; setting module to use Steam Browser Protocol mode RLLog.Info("PCLauncher - Application is a Steam Browser Protocol, setting mode to: """ . mode . """") } Else If (StringUtils.SubStr(Application,1,4) = "http") { mode := "url" ; setting module to use url mode RLLog.Info("PCLauncher - Application is a URL, setting mode to: """ . mode . """") } Else If OriginGame { mode := "origin" ; setting module to use Origin mode StringUtils.BackslashCheck(primaryExe.FileFullPath,"Application") RLLog.Info("PCLauncher - Origin mode enabled. Will log in to Origin if required.") } Else If Application { mode := "standard" ; for standard launching StringUtils.BackslashCheck(primaryExe.FileFullPath,"Application") RLLog.Info("PCLauncher - Setting mode to: """ . mode . """") } Else ; error if no modes are used ScriptError("Please set an Application, SteamID, Steam Browser Protocol, or URL in " moduleName . ".ini for """ . dbName . """") If (SteamID && Application) ; do not allow 2 launching methods as module cannot know which should be used ScriptError("You are trying to use Steam and an Application, you must choose one or the other.") If ((mode = "steam" || mode = "steambp") && !AppWaitExe && !FadeTitle) { ; && fadeIn = "true") { ; If AppWaitExe or FadeTitle are defined, that will take precedence over the automatic method using the SteamIDs.ini SteamIDFile := new IniFile(modulePath . "\SteamIDs.ini") SteamIDFile.CheckFile() If !SteamID ; if this game does not have a SteamID defined StringUtils.SplitPath(Application,SteamID) ; try to grab the ID from the Application name SteamIDExe := SteamIDFile.ReadCheck(SteamID, "exe",,,1) If !SteamIDExe ; if it was still not found, error out ScriptError("You are using launching a Steam game but no way for the module to know what window to wait for after launching. Please set a AppWaitExe, FadeTitle, or make sure your SteamID and the correct exe is defined in the SteamIDs.ini",10) Else { RLLog.Info("PCLauncher - Found an exe in the SteamIDs.ini for this game: """ . SteamIDExe . """") SteamIDExe := new Process(SteamIDExe) } } Else If (mode = "url" && !AppWaitExe && !FadeTitle) ScriptError("You are using launching a URL but no way for the module to know what to window to wait for after launching. Please set a AppWaitExe or FadeTitle to your default application that gets launched when opening URLs.",10) If (appIsImage && !primaryExe.FilePath) ; if user only defined an exe for Application with no path, assume it will be found on the root dir of the image when mounted primaryExe.FilePath := vdDriveLetter . ":\" If (!primaryExe.FileName && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing filename on the end of your Application in " . moduleName . ".ini:`n" . primaryExe.FileFullPath) If (!primaryExe.FileExt && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing extension on your Application in " . moduleName . ".ini:`n" . primaryExe.FileFullPath) PreLaunchExe := AltAppCheck(PreLaunch,"PreLaunch",PreLaunchIsURL) PostLaunchExe := AltAppCheck(PostLaunch,"PostLaunch",PostLaunchIsURL) PostExitExe := AltAppCheck(PostExit,"PostExit",PostExitIsURL) If (mode = "standard") primaryExe.CheckFile("Cannot find this Application:`n" . primaryExe.FileFullPath) ; keeping this last so more descriptive errors will trigger first RLLog.Info("CheckSettings - Ended") } AltAppCheck(file,id,ByRef urlID) { If file { obj := new Process(file) urlID := If (StringUtils.SubStr(file,1,4)="http" || StringUtils.SubStr(file,1,3)="ste") ? 1:"" If urlID RLLog.Info("PCLauncher - " . id . " is a URL or Steam Browser Protocol: " . file) Else { StringUtils.BackslashCheck(obj.FileFullPath,id) obj.CheckFile("Cannot find this " . id . " application:`n" . obj.FileFullPath) } Return obj } } HaltEmu: CustomFunction.HaltGame() Return RestoreEmu: CustomFunction.RestoreGame() Return CloseProcess: If (ExitMethod != "InGame") { FadeOutStart() If (ExitMethod = "Process Close AppWaitExe" && AppWaitExe) { RLLog.Info("CloseProcess - ExitMethod is ""Process Close AppWaitExe""") AppWaitExe.Process("Close") } Else If (ExitMethod = "WinClose AppWaitExe" && AppWaitExe) { RLLog.Info("CloseProcess - ExitMethod is ""WinClose AppWaitExe""") AppWaitExe.Process("Exist") AppWaitWindow := new Window(new WindowTitle(,,,,AppWaitExe.PID)) AppWaitWindow.Close() } Else If (ExitMethod = "Process Close Application") { RLLog.Info("CloseProcess - ExitMethod is ""Process Close Application""") primaryExe.Process("Close") } Else If (ExitMethod = "WinClose Application" && FadeTitle) { RLLog.Info("CloseProcess - ExitMethod is ""WinClose Close Application""") appPrimaryWindow.Close() } Else If (ExitMethod = "Send Alt+F4") { RLLog.Info("CloseProcess - ExitMethod is ""Send Alt+F4""") KeyUtils.Send("!{F4}") } Else { RLLog.Info("CloseProcess - Default ExitMethod`, using ""WinClose""") appPrimaryWindow.Close() } } Return 22:00:32:792 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 22:00:32:808 | RL | INFO | +16 | BuildScript - Loaded Statistics.ahk script 22:00:32:808 | RL | INFO | +0 | BuildScript - "F:\RocketLauncher\Lib\User Functions\Global.ahk" not found 22:00:32:808 | RL | INFO | +0 | BuildScript - "F:\RocketLauncher\Lib\User Functions\MAME.ahk" not found 22:00:32:808 | RL | INFO | +0 | BuildScript - "F:\RocketLauncher\Lib\User Functions\Emulators\PCLauncher.ahk" not found 22:00:32:808 | RL | INFO | +0 | BuildScript - "F:\RocketLauncher\Lib\User Functions\MAME\Emulators\PCLauncher.ahk" not found 22:00:32:808 | RL | INFO | +0 | BuildScript - "F:\RocketLauncher\Lib\User Functions\MAME\Killer Instinct.ahk" not found 22:00:32:808 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 22:00:32:808 | RL | INFO | +0 | Main - Module is built 22:00:32:808 | RL | INFO | +0 | CheckFile - Checking if F:\RocketLauncher\AutoHotkey.dll exists 22:00:32:808 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.13.00 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2003-2013 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.13.00 File Size: 802304 bytes Created: 9/7/2013 - 1:54:32 AM Modified: 10/3/2018 - 6:15:28 PM 22:00:32:823 | RL | INFO | +16 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 22:00:32:839 | RL | INFO | +15 | Main - Running module 22:00:32:990 | MD | INFO | +N/A | Module initialized 22:00:32:990 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 22:00:32:990 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 22:00:32:990 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 1 check 22:00:32:990 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 2 check 22:00:32:021 | MD | DEBUG | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 22:00:33:021 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 22:00:33:021 | MD | TRACE | +0 | CustomFunction.Init - Starting 22:00:33:021 | MD | TRACE | +0 | CustomFunction.Init - Ending 22:00:33:021 | MD | INFO | +0 | StartModule - Started 22:00:33:021 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: http://www.rlauncher.com/wiki/index.php?title=PCLauncher MAuthor: djvj MVersion: 2.2.7 MCRC: 5814E2E iCRC: 28F444EF MID: 635243126483565041 MSystem: American Laser Games|Arcade PC|Doujin Soft|Examu eX-BOARD|Fan Remakes|Games for Windows|Konami e-Amusement|Konami Bemani|Microsoft Windows|PCLauncher|PC Games|Singstar|Steam|Steam Big Picture|Taito Type X|Taito Type X2|Touhou|Touhou Project|Ultrastar|Ultrastar Deluxe|Windows Games 22:00:33:021 | MD | WARNING | +0 | StartModule - You have an unsupported System Name for this module: "MAME". Only the following System Names are suppported: "" 22:00:33:021 | MD | INFO | +0 | LocaleUtils.i18n - Started 22:00:33:021 | MD | DEBUG | +0 | LocaleUtils.i18n - Section "English_United_States" & key "dialog.open" not found, trying section "English" 22:00:33:021 | MD | INFO | +0 | LocaleUtils.i18n - Ended, using "Open" for "dialog.open" 22:00:33:021 | MD | INFO | +0 | LocaleUtils.i18n - Started 22:00:33:021 | MD | DEBUG | +0 | LocaleUtils.i18n - Section "English_United_States" & key "dialog.start" not found, trying section "English" 22:00:33:021 | MD | INFO | +0 | LocaleUtils.i18n - Ended, using "Start" for "dialog.start" 22:00:33:021 | MD | INFO | +0 | PluginInit - Started 22:00:33:021 | MD | DEBUG | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating 22:00:33:052 | MD | INFO | +31 | CheckFile - Checking if F:\HyperSpin\Databases\MAME\MAME.xml exists 22:00:33:052 | MD | DEBUG | +0 | CheckFile - Attributes: File Size: 3335126 bytes Created: 10/4/2018 - 8:40:14 PM Modified: 10/28/2018 - 2:48:07 PM 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Game Name" in the database! 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Name 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Name" with a value: "Killer Instinct (PC)" 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Cloneof 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Could not find: Cloneof 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Publisher 22:00:33:052 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Publisher" with a value: "Iron Galaxy" 22:00:33:084 | MD | DEBUG | +31 | BuildDatabaseTable - Searching database for: Year 22:00:33:084 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Year" with a value: "2013" 22:00:33:084 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Genre 22:00:33:084 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Genre" with a value: "Fighter / Versus" 22:00:33:084 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Rating 22:00:33:084 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Rating" with a value: "AAMA - Red (Animated Violence Strong)" 22:00:33:084 | MD | TRACE | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Fighter / Versus GameInfo Label: Name | GameInfo Value: Killer Instinct (PC) GameInfo Label: Publisher | GameInfo Value: Iron Galaxy GameInfo Label: Rating | GameInfo Value: AAMA - Red (Animated Violence Strong) GameInfo Label: Year | GameInfo Value: 2013 22:00:33:084 | MD | DEBUG | +0 | BuildDatabaseTable - Ended 22:00:33:084 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 22:00:33:084 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Logo: F:\HyperSpin\Media\MAME\Images\Wheel\Killer Instinct.png 22:00:33:084 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Logo: F:\HyperSpin\Media\Main Menu\Images\Wheel\MAME.png 22:00:33:084 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: F:\HyperSpin\Media\MAME\Images\Wheel\Killer Instinct.png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: F:\HyperSpin\Media\Main Menu\Images\Wheel\MAME.png | Asset Extension1: png | Asset Type1: system 22:00:33:084 | MD | INFO | +0 | BuildAssetsTable - Ended 22:00:33:084 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 22:00:33:084 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Artwork1: F:\HyperSpin\Media\MAME\Images\Artwork1\Killer Instinct.png 22:00:33:115 | MD | DEBUG | +32 | BuildAssetsTable - Searching for a Box Art: F:\HyperSpin\Media\MAME\Images\Artwork2\Killer Instinct.png 22:00:33:115 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Cartridge: F:\HyperSpin\Media\MAME\Images\Artwork3\Killer Instinct.png 22:00:33:115 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Flyers: F:\HyperSpin\Media\MAME\Images\Artwork4\Killer Instinct.png 22:00:33:115 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Letters: F:\HyperSpin\Media\MAME\Images\Letters 22:00:33:240 | MD | DEBUG | +125 | BuildAssetsTable - Searching for a Other: F:\HyperSpin\Media\MAME\Images\Other 22:00:33:240 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: F:\HyperSpin\Media\MAME\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: F:\HyperSpin\Media\MAME\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: F:\HyperSpin\Media\MAME\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: F:\HyperSpin\Media\MAME\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: F:\HyperSpin\Media\MAME\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: F:\HyperSpin\Media\MAME\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: F:\HyperSpin\Media\MAME\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: F:\HyperSpin\Media\MAME\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: F:\HyperSpin\Media\MAME\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: F:\HyperSpin\Media\MAME\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: F:\HyperSpin\Media\MAME\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: F:\HyperSpin\Media\MAME\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: F:\HyperSpin\Media\MAME\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: F:\HyperSpin\Media\MAME\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: F:\HyperSpin\Media\MAME\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: F:\HyperSpin\Media\MAME\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: F:\HyperSpin\Media\MAME\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: F:\HyperSpin\Media\MAME\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: F:\HyperSpin\Media\MAME\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: F:\HyperSpin\Media\MAME\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: F:\HyperSpin\Media\MAME\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: F:\HyperSpin\Media\MAME\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: F:\HyperSpin\Media\MAME\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: F:\HyperSpin\Media\MAME\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: F:\HyperSpin\Media\MAME\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: F:\HyperSpin\Media\MAME\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: F:\HyperSpin\Media\MAME\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: F:\HyperSpin\Media\MAME\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: F:\HyperSpin\Media\MAME\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: F:\HyperSpin\Media\MAME\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: F:\HyperSpin\Media\MAME\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: F:\HyperSpin\Media\MAME\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: F:\HyperSpin\Media\MAME\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: F:\HyperSpin\Media\MAME\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: F:\HyperSpin\Media\MAME\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: F:\HyperSpin\Media\MAME\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: F:\HyperSpin\Media\MAME\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: F:\HyperSpin\Media\MAME\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: F:\HyperSpin\Media\MAME\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: F:\HyperSpin\Media\MAME\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 22:00:33:240 | MD | INFO | +0 | BuildAssetsTable - Ended 22:00:33:240 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 22:00:33:240 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Video: F:\HyperSpin\Media\MAME\Video\Killer Instinct.* 22:00:33:240 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Video: F:\HyperSpin\Media\Main Menu\Video\MAME.* 22:00:33:271 | MD | DEBUG | +31 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: F:\HyperSpin\Media\MAME\Video\Killer Instinct.mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: System Video | Asset Path1: F:\HyperSpin\Media\Main Menu\Video\MAME.mp4 | Asset Extension1: mp4 | Asset Type1: system 22:00:33:271 | MD | INFO | +0 | BuildAssetsTable - Ended 22:00:33:271 | MD | INFO | +0 | PluginInit - Ended 22:00:33:271 | MD | DEBUG | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: Killer Instinct 22:00:33:271 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 22:00:33:302 | MD | DEBUG | +31 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc, 22:00:33:302 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 1 check 22:00:33:302 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 2 check 22:00:33:302 | MD | DEBUG | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 22:00:33:302 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 22:00:33:302 | MD | TRACE | +0 | Process.__New - Creating new process object for: "F:\HyperSpin\HyperSpin.exe" 22:00:33:302 | MD | TRACE | +0 | File.__New - Creating new file object of: "F:\HyperSpin\HyperSpin.exe" 22:00:33:302 | MD | TRACE | +0 | File.__New - Creating new file object of: "F:\RocketLauncher\Modules\PCLauncher\MAME\Killer Instinct.ini" 22:00:33:302 | MD | TRACE | +0 | File.__New - Creating new file object of: "F:\RocketLauncher\Modules\PCLauncher\MAME.ini" 22:00:33:333 | MD | TRACE | +31 | File.__New - Creating new file object of: "F:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini" 22:00:33:333 | MD | TRACE | +0 | File.Exist - This file exists: F:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini 22:00:33:365 | MD | DEBUG | +32 | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "F:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini" 22:00:33:365 | MD | INFO | +0 | StartModule - Ended 22:00:33:365 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - Application: ..\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe 22:00:33:391 | MD | TRACE | +31 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - AppWaitExe: No value for this key 22:00:33:394 | MD | INFO | +0 | RIniFile.Read - Module - AppWaitExe: (NO VALUE) 22:00:33:396 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - DiscImage: No value for this key 22:00:33:399 | MD | INFO | +0 | RIniFile.Read - Module - DiscImage: (NO VALUE) 22:00:33:401 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - DXWndGame: No value for this key 22:00:33:429 | MD | INFO | +31 | RIniFile.Read - Module - DXWndGame: (NO VALUE) 22:00:33:431 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - DXWndMaximizeWindow: No value for this key 22:00:33:433 | MD | INFO | +0 | RIniFile.Read - Module - DXWndMaximizeWindow: (NO VALUE) 22:00:33:451 | MD | TRACE | +31 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - ExitMethod: No value for this key 22:00:33:453 | MD | INFO | +0 | RIniFile.Read - Module - ExitMethod: (NO VALUE) 22:00:33:454 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - FadeTitle: No value for this key 22:00:33:456 | MD | INFO | +0 | RIniFile.Read - Module - FadeTitle: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - FadeTitleWaitTillActive: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - FadeTitleWaitTillActive: true (DEFAULT) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - FadeTitleTimeout: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - FadeTitleTimeout: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - FadeInExitSleep: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - FadeInExitSleep: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - HideConsole: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - HideConsole: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - OriginGame: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - OriginGame: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - Parameters: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - Parameters: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PostLaunch: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunch: (NO VALUE) 22:00:33:458 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PostLaunchParameters: No value for this key 22:00:33:458 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunchParameters: (NO VALUE) 22:00:33:490 | MD | TRACE | +32 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PostLaunchSleep: No value for this key 22:00:33:490 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunchSleep: (NO VALUE) 22:00:33:490 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PostExit: No value for this key 22:00:33:490 | MD | INFO | +0 | RIniFile.Read - Module - PostExit: (NO VALUE) 22:00:33:490 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PostExitParameters: No value for this key 22:00:33:521 | MD | INFO | +31 | RIniFile.Read - Module - PostExitParameters: (NO VALUE) 22:00:33:521 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PostExitSleep: No value for this key 22:00:33:521 | MD | INFO | +0 | RIniFile.Read - Module - PostExitSleep: (NO VALUE) 22:00:33:521 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PreLaunch: No value for this key 22:00:33:521 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunch: (NO VALUE) 22:00:33:521 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PreLaunchParameters: No value for this key 22:00:33:521 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchParameters: (NO VALUE) 22:00:33:521 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PreLaunchMode: No value for this key 22:00:33:521 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchMode: (NO VALUE) 22:00:33:521 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - PreLaunchSleep: No value for this key 22:00:33:521 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchSleep: (NO VALUE) 22:00:33:521 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - SteamID: No value for this key 22:00:33:521 | MD | INFO | +0 | RIniFile.Read - Module - SteamID: (NO VALUE) 22:00:33:552 | MD | TRACE | +31 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - WorkingFolder: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - WorkingFolder: (NO VALUE) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - BezelTopOffset: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - BezelTopOffset: 0 (DEFAULT) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - BezelBottomOffset: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - BezelBottomOffset: 0 (DEFAULT) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - BezelLeftOffset: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - BezelLeftOffset: 0 (DEFAULT) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - BezelRightOffset: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - BezelRightOffset: 0 (DEFAULT) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - BezelFixedResMode: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - BezelFixedResMode: false (DEFAULT) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - HideWindowTitleBar: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowTitleBar: true (DEFAULT) 22:00:33:552 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - HideWindowBorder: No value for this key 22:00:33:552 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowBorder: true (DEFAULT) 22:00:33:583 | MD | TRACE | +31 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - HideWindowMenuBar: No value for this key 22:00:33:583 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowMenuBar: true (DEFAULT) 22:00:33:583 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - HideDecoratorsAfterWindowMove: No value for this key 22:00:33:583 | MD | INFO | +0 | RIniFile.Read - Module - HideDecoratorsAfterWindowMove: false (DEFAULT) 22:00:33:583 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - HideWindowBorderFirst: No value for this key 22:00:33:583 | MD | INFO | +0 | RIniFile.Read - Module - HideWindowBorderFirst: false (DEFAULT) 22:00:33:583 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Killer Instinct] - Fullscreen: No value for this key 22:00:33:583 | MD | INFO | +0 | RIniFile.Read - Module - Fullscreen: (NO VALUE) 22:00:33:583 | MD | TRACE | +0 | CustomFunction.PreStart - Starting 22:00:33:583 | MD | TRACE | +0 | CustomFunction.PreStart - Ending 22:00:33:583 | MD | TRACE | +0 | Emulator.__New - Creating new emulator object for: "..\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" 22:00:33:583 | MD | TRACE | +0 | Process.__New - Creating new process object for: "..\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" 22:00:33:583 | MD | TRACE | +0 | File.__New - Creating new file object of: "..\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" 22:00:33:615 | MD | INFO | +32 | CheckSettings - Started 22:00:33:615 | MD | TRACE | +0 | StringUtils.SubStr - Retrieved "..\" from "..\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" 22:00:33:646 | MD | TRACE | +31 | StringUtils.SubStr - Retrieved "..\P" from "..\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" 22:00:33:646 | MD | INFO | +0 | PCLauncher - Setting mode to: "standard" 22:00:33:646 | MD | INFO | +0 | File.CheckFile - Checking if "F:\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" exists 22:00:33:646 | MD | TRACE | +0 | File.Exist - This file exists: F:\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe 22:00:33:677 | MD | DEBUG | +31 | File.CheckFile - Attributes: FileDescription Killer Instinct FileVersion 1.0.0.0 InternalName Killer Instinct LegalCopyright Copyright © 2013 OriginalFilename KillerInstinct.exe ProductName Killer Instinct ProductVersion 1.0.0.0 CompanyName Microsoft File Size: 48479440 bytes Created: 8/17/2018 - 10:46:13 AM Modified: 8/17/2018 - 10:46:13 AM 22:00:33:677 | MD | INFO | +0 | CheckSettings - Ended 22:00:33:677 | MD | TRACE | +0 | CustomFunction.SetFullscreenPreLaunch - Starting 22:00:33:677 | MD | TRACE | +0 | CustomFunction.SetFullscreenPreLaunch - Setting fullscreen to 22:00:33:708 | MD | TRACE | +31 | CustomFunction.SetFullscreenPreLaunch - Ending 22:00:33:708 | MD | TRACE | +0 | StringUtils.Contains - "standard" does not contain "steam|steambp" 22:00:33:708 | MD | INFO | +0 | PCLauncher - Launching a standard application. 22:00:33:708 | MD | TRACE | +0 | CustomFunction.PreLaunch - Starting 22:00:33:708 | MD | TRACE | +0 | CustomFunction.PreLaunch - Ending 22:00:33:740 | MD | INFO | +32 | Process.Run - Running: "F:\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe" 22:00:33:817 | MD | DEBUG | +78 | Process.Run - "KillerInstinctX64_r.exe" Process ID: 7264 22:00:33:817 | MD | TRACE | +0 | CustomFunction.PostLaunch - Starting 22:00:33:817 | MD | TRACE | +0 | CustomFunction.PostLaunch - Ending 22:00:33:817 | MD | INFO | +0 | PCLauncher - FadeTitle and AppWaitExe not set by user, but a PID for the primary application was found. Waiting for PID: 7264 22:00:33:817 | MD | TRACE | +0 | CustomFunction.PreBezelDraw - Starting 22:00:33:817 | MD | TRACE | +0 | CustomFunction.SetFullscreenPostLaunch - Starting 22:00:33:817 | MD | TRACE | +0 | CustomFunction.SetFullscreenPostLaunch - Setting fullscreen to false 22:00:33:817 | MD | TRACE | +0 | CustomFunction.SetFullscreenPostLaunch - Ending 22:00:33:817 | MD | TRACE | +0 | CustomFunction.PreBezelDraw - Ending 22:00:33:817 | MD | TRACE | +0 | TimerUtils.Sleep - Sleeping for milliseconds 22:00:33:817 | MD | TRACE | +0 | CustomFunction.PostLoad - Starting 22:00:33:849 | MD | TRACE | +31 | CustomFunction.PostLoad - Ending 22:00:33:849 | MD | INFO | +0 | PCLauncher - Creating a window based on the Primary Application "KillerInstinctX64_r.exe" because FadeTitle nor AppWaitExe were set 22:00:33:849 | MD | TRACE | +0 | Window.__New - Created: "ahk_pid 7264" 22:00:33:849 | MD | TRACE | +0 | Window.__New - Created: "ahk_id 132786" 22:00:33:849 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 22:00:33:849 | MD | TRACE | +0 | Window.GetPos - Retrieved x:1086 y:419 w: 1108 h: 960 from "ahk_id 132786" 22:00:33:849 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 22:00:33:849 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.10 [ FE = HyperSpin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;cbf25c93-93ab-4a18-90aa-a7496afaba7e] | State: 0 | X: 1086 | Y: 419 | Width: 1108 | Height: 960 | Window HWND: 0x206b2 | Process ID: 11056 | Process Path: F:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe 22:00:33:849 | MD | INFO | +0 | Window.Wait - Waiting for window "ahk_pid 7264" 22:01:03:841 | MD | TRACE | +30000 | Window.__New - Created: "ahk_id 525410" 22:01:03:846 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 22:01:03:849 | MD | TRACE | +0 | Window.GetPos - Retrieved x:0 y:0 w: 2560 h: 1440 from "ahk_id 525410" 22:01:03:850 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 22:01:03:852 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: Killer Instinct | Class: Killer Instinct | State: 0 | X: 0 | Y: 0 | Width: 2560 | Height: 1440 | Window HWND: 0x80462 | Process ID: 4424 | Process Path: F:\Program Files\steamapps\common\Killer Instinct\KillerInstinctX64_r.exe 22:01:03:853 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 22:01:03:855 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 22:01:03:874 | MD | DEBUG | +31 | XHotkeyTableCreation - Post loop 10 check 22:01:03:876 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:01:03:878 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 22:01:03:879 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 22:01:03:881 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 22:01:03:883 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 22:01:03:884 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 22:01:03:886 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 22:01:03:909 | MD | DEBUG | +31 | XHotkeyTableCreation - Post loop 10 check 22:01:03:911 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:01:03:912 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 22:01:03:914 | MD | DEBUG | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError" 22:01:03:916 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 22:01:03:918 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 22:01:04:365 | MD | DEBUG | +454 | ScriptError - Playing error sound: error6.mp3 22:01:17:052 | MD | DEBUG | +12687 | XHotkeyTableCreation - Started 22:01:17:057 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 22:01:17:058 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 10 check 22:01:17:079 | MD | DEBUG | +31 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:01:17:080 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 22:01:17:081 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc" 22:01:17:083 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 22:01:17:084 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 22:01:17:085 | MD | DEBUG | +0 | XHotkeyTableCreation - Started 22:01:17:086 | MD | DEBUG | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~e&~t, 22:01:17:087 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 10 check 22:01:17:088 | MD | DEBUG | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:01:17:089 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 11 check 22:01:17:112 | MD | DEBUG | +32 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 22:01:17:113 | MD | DEBUG | +0 | XHotkeyTableCreation - Post loop 12 check 22:01:17:114 | MD | DEBUG | +0 | XHotkeyTableCreation - Ended 22:01:17:117 | MD | ERROR | +0 | ScriptError - There was an error waiting for the window "ahk_pid 7264". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 22:01:17:118 | MD | INFO | +0 | ExitModule - Started 22:01:17:119 | MD | INFO | +0 | UpdateStatistics - Starting Updating Statistics 22:01:17:141 | MD | DEBUG | +31 | UpdateStatistics - Total Elapsed Time in Pause in seconds: 0 22:01:17:142 | MD | DEBUG | +0 | UpdateStatistics - gameSectionStartTime:177251125 22:01:17:143 | MD | DEBUG | +0 | UpdateStatistics - ElapsedTime:43 22:01:17:145 | MD | TRACE | +0 | Statistics cleared game name: Killer Instinct 22:01:17:182 | MD | DEBUG | +31 | UpdateStatistics - Loaded game statistics from ini files: Number_of_Times_Played: 5 Last_Time_Played: Monday October 29, 2018 08:49:27 PM Average_Time_Played: 36 Total_Time_Played: 182 System_Total_Played_Time: 7812 Total_Global_Played_Time: 8112 22:01:17:200 | MD | DEBUG | +31 | UpdateStatistics - Updated Statistics: Number_of_Times_Played: 6 Last_Time_Played: Monday October 29, 2018 10:00:33 PM Average_Time_Played: 38 Total_Time_Played: 225 System_Total_Played_Time: 7855 Total_Global_Played_Time: 8155 22:01:17:245 | MD | INFO | +32 | UpdateStatistics - Game section statistics updated. 22:01:17:246 | MD | TRACE | +0 | CustomFunction.PostExit - Starting 22:01:17:267 | MD | TRACE | +31 | CustomFunction.PostExit - Ending 22:01:17:268 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 22:01:17:393 | RL | INFO | +44563 | Main - Module ended, exiting RocketLauncher normally 22:01:17:397 | RL | INFO | +0 | ExitScript - Started 22:01:17:418 | RL | DEBUG | +31 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 22:01:17:420 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 22:01:17:421 | RL | TRACE | +0 | StringUtils.Contains - "false" does not contain "true|kill" 22:01:17:423 | RL | INFO | +0 | ExitScript - Restoring taskbar 22:01:17:424 | RL | TRACE | +0 | Window.__New - Created: "ahk_class Shell_TrayWnd" 22:01:17:426 | RL | TRACE | +0 | Window.__New - Created: "ahk_class Button" 22:01:17:427 | RL | TRACE | +0 | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 22:01:17:531 | RL | TRACE | +109 | Window.Show - Unhiding window "ahk_class Button" 22:01:17:544 | RL | INFO | +16 | SystemCursor - Restoring mouse cursor 22:01:17:553 | RL | INFO | +0 | ExitScript - Restored cursor 22:01:17:555 | RL | INFO | +0 | ExitScript - Ended
Spawk Posted October 30, 2018 Posted October 30, 2018 Only use the path to the exe in non-steam games. Try to get used to setting the appwait.exe (and fade title) for these. If the game is in your steam then it is much better to just use the steamID... here is a thread with more info
pmindemann Posted October 30, 2018 Author Posted October 30, 2018 Interesting, Spawk--thank you. My understanding was that you could use one or the other... direct launch via the .exe, or through the Steam ID. I'll try to latter, but assumed the former would be more direct (and seemed to work fine with a different title). I don't know enough to know the difference between the two or why it would matter, but appreciate the advice!
