lmsilva Posted May 31, 2014 Posted May 31, 2014 Hello everyone, I was wondering if there is a tool to automatically generate wheel banners from text? I know that Hyperspin automatically generates text based wheels if no banners are available BUT, I'm having a problem where my text wheels will be put behind the theme's images, so I stop seeing them as soon as the theme loads. Here's a video showing what is happening: I know that, if I remove the theme OR the background image / swf, the wheel text still displays. But since I want to keep the background, it seems the only alternative is to generate wheels (even if they just contain text). Do you know of any application / web service that does this? Thank you, Luis
manicshere Posted May 31, 2014 Posted May 31, 2014 It shouldn't make any difference if the wheels are text or images. Problem is that Commander Keen is placed on the wrong layer in the theme. Was this downloaded through Hypersync, the FTP or elsewhere? I'll be able to fix it for you if I can get the theme.
lmsilva Posted May 31, 2014 Author Posted May 31, 2014 I really appreciate your help dude! Here's the theme: http://www.filedropper.com/default I've downloaded it from the official website (it is one of the available msdos themes). It shouldn't make any difference if the wheels are text or images. Problem is that Commander Keen is placed on the wrong layer in the theme. Was this downloaded through Hypersync, the FTP or elsewhere? I'll be able to fix it for you if I can get the theme.
lmsilva Posted May 31, 2014 Author Posted May 31, 2014 I've uploaded all files (database and themes) here: https://filetea.me/t1sqgvrAsoyRB6JKI4p9aWccA I really appreciate your help dude!Here's the theme: http://www.filedropper.com/default I've downloaded it from the official website (it is one of the available msdos themes).
32assassin Posted May 31, 2014 Posted May 31, 2014 I never used this app not sure how it works but it looks like something you can use. type in the name of your game with the font you like to use and create a basic wheel image http://www.hyperspin-fe.com/forum/showthread.php?30207-Simple-System-Wheel-Creator Here's the theme: http://www.filedropper.com/default . (not the same theme you are using) different characters in theme. but if you move current background -- > delete Artwork 1 --> background you will have a better theme, Artwork 1 is a full screen image and is blocking your wheels
lmsilva Posted May 31, 2014 Author Posted May 31, 2014 Awesome dude! That fixed it. Your suggestion made perfect sense ) I should have noticed that myself heheh. I never used this app not sure how it works but it looks like something you can use.type in the name of your game with the font you like to use and create a basic wheel image http://www.hyperspin-fe.com/forum/showthread.php?30207-Simple-System-Wheel-Creator (not the same theme you are using) different characters in theme. but if you move current background -- > delete Artwork 1 --> background you will have a better theme, Artwork 1 is a full screen image and is blocking your wheels
