JDrake Posted November 8, 2018 Posted November 8, 2018 How do I get the emulator to show up in the UI? Any suggestions?
adamg Posted November 8, 2018 Posted November 8, 2018 If you have none there, you will need to navigate to the Rocketlauncher/Settings/ folder and copy the Global Emulators (Example) and rename it to Global Emulators. I would also recommend you watch Avar's installation videos. If you have done the above and just want to add one that is not there, you will need to add it to the Global Emulators config file found in the Rocketlauncher/Settings/ folder. The syntax is as follows: [emulator name] Emu_Path= Rom_Extension= Module= Pause_Save_State_Keys= Pause_Load_State_Keys= As you add stuff to the global emulator tab in the UI, you will see it added to this snipit of code. Or you can just enter it there directly.
