Help Hyperspin wont launch games
brihff1972
It loads gets to the menus but will not load a game
:ere is what Im getting in log.
8:32:05 PM |  HyperSpin Started
08:32:05 PM |  Going FullScreen
08:32:05 PM |  Checking for updates
08:32:05 PM |  Update Check Complete
08:32:05 PM |  Startup program unavailable
08:32:05 PM |  Playing intro video
08:32:23 PM |  Error intializing joysticks
08:32:23 PM |  Menu Mode is multi
08:32:23 PM |  Loading Main Menu.xml
08:32:24 PM |  Main Menu.xml successfully loaded
08:32:24 PM |  Main Menu wheel loaded successfully
08:32:28 PM |  Loading Daphne.xml
08:32:28 PM |  Main Menu.xml successfully loaded
08:32:28 PM |  Daphne wheel loaded successfully
08:32:30 PM |  Launching Game
08:32:30 PM |  Using HyperLaunch
08:32:30 PM |  Getting Launcher path
08:32:30 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
08:32:30 PM |  Launcher located at R:\Arcade\HyperLaunch.exe
08:32:30 PM |  Running Launcher
08:32:30 PM |  Launcher Command Line is: R:\Arcade\HyperLaunch.exe "Daphne" "lair"
08:32:32 PM |  Launching Game
08:32:32 PM |  Using HyperLaunch
08:32:32 PM |  Getting Launcher path
08:32:32 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
08:32:32 PM |  Launcher located at R:\Arcade\HyperLaunch.exe
08:32:32 PM |  Running Launcher
08:32:32 PM |  Launcher Command Line is: R:\Arcade\HyperLaunch.exe "Daphne" "lair"
08:32:33 PM |  Launching Game
08:32:33 PM |  Using HyperLaunch
08:32:33 PM |  Getting Launcher path
08:32:33 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
08:32:33 PM |  Launcher located at R:\Arcade\HyperLaunch.exe
08:32:33 PM |  Running Launcher
08:32:33 PM |  Launcher Command Line is: R:\Arcade\HyperLaunch.exe "Daphne" "lair"
08:32:34 PM |  Launching Game
08:32:34 PM |  Using HyperLaunch
08:32:34 PM |  Getting Launcher path
08:32:34 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
08:32:34 PM |  Launcher located at R:\Arcade\HyperLaunch.exe
08:32:34 PM |  Running Launcher
08:32:34 PM |  Launcher Command Line is: R:\Arcade\HyperLaunch.exe "Daphne" "lair"
08:32:37 PM |  Loading Main Menu.xml
08:32:37 PM |  Main Menu.xml successfully loaded
08:32:38 PM |  Main Menu wheel loaded successfully
08:32:41 PM |  Exit program unavailable
08:32:41 PM |  Quiting Hyperspin
08:32:41 PM |  Bye!
go back and read install tutorials
you do not have a correct path to RL,  it can't find it so its using the default Hyerlaunch.exe
