ctopher2391 Posted February 8, 2019 Posted February 8, 2019 Hi everyone, I have an xtension controller and cabinet that I purchased from Rec Room Masters. I followed tutorials and installed Hyperspin + RocketLauncher. Everything is working great except for a couple of small problems with mapping. I'm attaching a screenshot of my hyperHQ mappings. The controller is ultramart mini pac. When I open notepad and press the controller 2 buttons, I receive asqwikjl (in that order from top left to right). I assume one issue is "Q" in HyperHQ is set to exit. And of course when that button is pressed in a game, it exits. Is the solution to this as simple as changing the HyperHQ mapping to something different and random like #9 ? Also the buttons on player 1 and player 2 don't align. For example when playing NBA Jam, the shoot button on player 1 is different from player 2. What's the easiest way to fix this? I asked RecRoomMasters about flashing the firmware based on something I read on a different forum and they did not recommend I do that. HyperHQ.rtf
32assassin Posted February 8, 2019 Posted February 8, 2019 your controller was built with an ipac an Ipac is pre configured with the MAME keys this are the keys https://www.ultimarc.com/ipac2.html if your game is exiting when you press the Q, you either need to change this in Rocketlauncher (exit key) or you need to download the Ipac programming software https://www.ultimarc.com/winipacv2.html and change Player 2 button 3 from "Q" to something else (side not this might break your MAME controllers, so you will need to updated all your emulators so that it works with the key you selected) and if you want to change the buttons on your NBA game load the game press "Tab" and make a Per game controller config file you can change the button keys for the game without flashing your firmware.
