Atari 5200 not working
Godfather
Has anyone got the Atari 5200 emulator to work with the newest versions of hyperspin/rocket launcher?
i've tried Kat , mess, a800 and retro arch!?
Thanks again folks,
Mess is basically a MESS, you need software lists from mame and other stuff.
Atari800 works BUT you must have A5200.rom in system, press f1 and select the bios folder from atari800 menu. The fun fact is core information find the bios BUT you must select the folder from core's GUI
i opened the program hit F1, i cannot find the location of the bios where am i supposed to look for that? Also where does one get the a5200.rom?
Sorry just having trouble understanding that.
That was brilliant!! i think my issue is i do not have a "bios" folder in my emulator atari800 folder. I leave my bios files in my rom folder but none of those are working? got any more screen shots lol
i appreciate you!
It's a problem with RA itself: if you go to core information it says the rom is there if you have it in RA "system" folder BUT the core can't find it, so you'll have to reassign the path from the emulator itself just press F!, F1 again (it opens the emulator's GUI AND Ra's GUI), follow that screnshots then find assign the rom and save configuration
ah, so i need to download Retro Arch?
so i go
F1 > Emulator Configuration > System ROM settings > 5200 BIOS ROM locations >
from here do i select "orginal", "rev", or "Custom"?
Also i am selecting the bios file that should be in Retro arch?
again thank you,
I use RA for CRT shaders, it should be the same thing in the standalone emulator, I guess. I setted it as "original". Probably you'll have to set the system to "atari 5200" somewhere in that menu.
where is the 5200.rom coming from? is that something i need to download separately or is that generated from RA?
8 minutes ago, dark13 said:
You need to find it separately, it's atari 5200 bios.
GOT IT!~!! i had to rename the atari bios file from .a52 to .rom and she worked with the steps you provided!
thanks again brother!!
