Run AHK code only if running extended desktop?
Dime333
Does anyone have an idea how to achieve this? I want to make a script that checks if you are running extended desktop and then execute certain code only if that is true.
Edit: I guess I could check the screen width and just execute the code if it's greater than my normal screen width (1920). Not sure if extended desktop works like that or if the screen width would still be 1920. But even if that works, it wouldn't work for anyone who is using a 4K screen for example. I'm just brainstorming. I can't test it right now.
Edit 2: I think this will work even better than what I was hoping for. Will do some testing.
SysGet, OutputVar, MonitorName , N
