mattbodin Posted June 3, 2014 Posted June 3, 2014 I Want to integrate HS into WMC7, how can I do this? I've searched for a while and found literally nothing. But I really don't think it should be that hard. WMC just needs an entry(start item) for hyperspin, I could start WMC via hyperspins exit options I am going to be using an X360 wireless controller and would like not to use anything else. Thanks, Matt
Fromlostdays Posted June 3, 2014 Posted June 3, 2014 I'm not very savvy, but it wouldn't be hard to make a wheel dedicated solely to launch the exe. Just create a wheel then set it up like you'd set up any other PC game, then set xpadder to control wmc. That's not very integrated but you could launch it pretty easily I would think. Look up how to launch pc games and exes from Hyperspin. Walter:beerglass:
Cryofax Posted June 3, 2014 Posted June 3, 2014 I'm exploring something like this too. I can't decide if I should make Hyperspin the default and create it's own media page (to launch WMC, Netflix, HBOGo, Hulu) or reverse it and have WMC as default with a way to launch Hyperspin (and those other things) or even go with something like XBMC or Media Browser which launches those. lol. So many options. I will say from my research that just about every combination IS doable.
Fromlostdays Posted June 3, 2014 Posted June 3, 2014 Would be awesome to have hyperspin as the default- the only problem is you'd probably have to make a lot of your own artwork. I haven't tested this yet but you might be able to have Hyperspin directly launch VLC playlists. So if you are as into cartoons as I am, you could make a wheel solely for your 500 gig cartoon collection. Walter:beerglass:
Cryofax Posted June 3, 2014 Posted June 3, 2014 Would be awesome to have hyperspin as the default- the only problem is you'd probably have to make a lot of your own artwork. I haven't tested this yet but you might be able to have Hyperspin directly launch VLC playlists. So if you are as into cartoons as I am, you could make a wheel solely for your 500 gig cartoon collection. If you created a system page with the extension the cartoons use (mp4, avi, whatever) and the "emulator" exe (in this case video player) simply set to launch with a command line to the file (i.e. potplayer.exe somecartoon.avi). You would be able to scroll through your cartoon names and pick one. I imagine "box art" would be easy to come up with for each show too. If you wanted a video "preview" you could just let it play the actual video in a box, though I'd probably skip that one myself.
