jpv108 Posted June 4, 2014 Posted June 4, 2014 Hey all, Question... has anyone's HyperHQ setting.ini file been erased randomly? This has now happened to me three times over the past couple months. If so, am I doing something to cause this? Example: Just now for instance... I turned on my arcade cab and everything booted up to Windows XP as usual. I double click the HyperSpin icon and it goes right to my main wheel (no intro - the first sign something is up) with none of my customized controls working. I back out of HyperSpin and double click HyperHQ... all settings are erased. Nothing is in the boxes for controls... all blank. The path to HyperLaunch is back to default so I get an error when trying to load games via HyperSpin. I have now backed up my settings.ini file and just do a quick copy to get everything back to normal. Just wondering if anyone else is running into this. Gets kind of annoying but not to the breaking point yet.
rfancella Posted June 4, 2014 Posted June 4, 2014 Hey all,Question... has anyone's HyperHQ setting.ini file been erased randomly? This has now happened to me three times over the past couple months. If so, am I doing something to cause this? Example: Just now for instance... I turned on my arcade cab and everything booted up to Windows XP as usual. I double click the HyperSpin icon and it goes right to my main wheel (no intro - the first sign something is up) with none of my customized controls working. I back out of HyperSpin and double click HyperHQ... all settings are erased. Nothing is in the boxes for controls... all blank. The path to HyperLaunch is back to default so I get an error when trying to load games via HyperSpin. I have now backed up my settings.ini file and just do a quick copy to get everything back to normal. Just wondering if anyone else is running into this. Gets kind of annoying but not to the breaking point yet. I wrote a small batch file that backs up all your HyperHQ & HyperLaunch ini files, database files, HyperLaunch modules and HyperLaunch Profiles. You place the batch file in your HyperSpin directory and double click it. It will keep 5 sets of backups. So anytime you make a change, run the batch. Here is the batch file: @ECHO OFF SETLOCAL rmdir /s /q Backups\HSBackup6 Echo Backup #6 Deleted move Backups\HSBackup5 Backups\HSBackup6 Echo Moved Backup 5 to 6 move Backups\HSBackup4 Backups\HSBackup5 Echo Moved Backup 4 to 5 move Backups\HSBackup3 Backups\HSBackup4 Echo Moved Backup 3 to 4 move Backups\HSBackup2 Backups\HSBackup3 Echo Moved Backup 2 to 3 move Backups\HSBackup1 Backups\HSBackup2 Echo Moved Backup 1 to 2 mkdir Backups\HSBackup1 SET _source=Settings SET _dest=Backups\HSBackup1\Settings SET _options=/R:0 /W:0 /LOG:Backups\HSBackup1\MyHSBackup.txt /NFL /NDL :: /R:n :: number of Retries :: /W:n :: Wait time between retries :: /LOG :: Output log file :: /NFL :: No file logging :: /NDL :: No dir logging CALL :RUN Echo HS Settings Done SET _options=/R:0 /W:0 /LOG+:Backups\HSBackup1\MyHSBackup.txt /NFL /NDL :: /R:n :: number of Retries :: /W:n :: Wait time between retries :: /LOG :: Output log file :: /NFL :: No file logging :: /NDL :: No dir logging SET _source=Databases SET _dest=Backups\HSBackup1\Databases CALL :RUN Echo HS Databases Done SET _source=HyperLaunch\Settings SET _dest=Backups\HSBackup1\HyperLaunch\Settings CALL :RUN Echo HL Settings Done SET _source=HyperLaunch\Modules SET _dest=Backups\HSBackup1\HyperLaunch\Modules CALL :RUN Echo HL Modules Done SET _source=HyperLaunch\Profiles SET _dest=Backups\HSBackup1\HyperLaunch\Profiles CALL :RUN Echo HL Profiles Done SET _source=HyperLaunch\Data SET _dest=Backups\HSBackup1\HyperLaunch\Data CALL :RUN Echo HL Data Done GOTO :EOF :RUN SET _what=/COPYALL /B /SEC /MIR :: /COPYALL :: COPY ALL file info :: /B :: copy files in Backup mode. :: /SEC :: copy files with SECurity :: /MIR :: MIRror a directory tree ROBOCOPY %_source% %_dest% %_what% %_options% :EOF Just create a new txt document and paste this into it. Rename it to Backup.cmd and run it. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
jpv108 Posted June 4, 2014 Author Posted June 4, 2014 I'll give it a try... Thank Ron! Much appreciated!
relic Posted June 5, 2014 Posted June 5, 2014 your a genious rfan so many useful scripts you make for us big thanks from relic 100%
rfancella Posted June 5, 2014 Posted June 5, 2014 your a genious rfan so many useful scripts you make for us big thanks from relic Thank you Relic! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
