HyperHQ wont save entries
lewsidius45
HyperHQ wont save entries. with every emulator I am using I try to enter the extensions and rom paths but the second I either close or move to the next emulator. If I go back to what I just did it goes back to empty. Dont know why this is happening, kinda weird. I upgraded to try to fix it with no luck
am I doing anything wrong? any tips?
any changes you make in HyperHQ are saved on
C:\HyperSpin\Settings\EmulatorNAME.ini
make sure that your  Settings folder and all the files inside that folder are not set to read only
and the only reason you should be adding rom paths and extensions in HyperHQ is if you wan to use rom filtering.
rom paths to find and load your roms on en emulator are saved in Rocketaluncher
