retroarch on HS problem
zebi
Hello everybody
I have a problem with hyperspin. emulator is retroarch for systems by sega. in the rocketlauncher the emulator runs and the game starts. in hyperspin the emulator does not start. There is also no error message.
Can anyone help me ?
wanted to take the bizhawk but there is the same problem
Emu Samler
If it works in Rocketlauncher then it's the connection between Hyperspin and Rocketlauncher. Can you post your Hyperspin log?
  • 3 weeks later...
I think you need to set the Rom Path and Extensions within HyperHQ. Open up HyperHQ and go to wheel settings then choose a wheel for the particular emulator you will be using within hyperspin. Next, at "Rom Path:" there is a folder icon you need to click and give the path for where your roms are located for that particular emulator. Now you must put in the extensions that your emulator roms will use in "Extensions:". For instance, for mame, my roms are zipped up so I inputted "7z,zip,rar,chd" into that box. No spaces and comma's separating the different extensions.
