MAME help
Turnquest
Hi all,
A few days ago my hard drive died, the boot drive of my Hyperspin pc. Luckily, I have most of my Hyperspin setup and emulators on an external hard drive. So, after installing a new boot drive (upgrading from Windows Vista to Windows 7 in the process) I got my setup running again. Most of my emulators seem to be running just fine, even though a few needs setting up again. So far so good. But I have a problem with MAME that I just can't solve. I can't use my HLSL settings anymore. They worked fine when using my previous boot drive (Windows Vista). But after my new Windows installation nothing happens when I turn on HLSL in the MAME ini file. I know MAME reads the ini file, because when I make other changes it works. And when I move the external HD to another PC, HLSL works fine. This other pc is using Windows 7 too.
I am using an old MAME version (0145) but it has worked good for me up until now. I have tried installing newer versions of MAME (0146 and 0147) but the problem is the same - HLSL does not work with these versions either. I just can't figure this out. It all worked in the past, and the exact setup works on another pc. Can anybody help? Please, please, please before I lose my sanity...
Thanks!
You mean in the Hyperspin module? It's all set in Hyperspin. And I have been trying MAME outside of Hyperspin, and no luck with HLSL there either. I really have no clue here...
I did a video guide for HLSL, check it out and see if you missed something.
I'm using Mameuifx version 0.153 btw.
