IronMan8Bit Posted June 19, 2019 Posted June 19, 2019 I'm using all the newest versions of HyperSpin(1.5.1 with Upgrades File) and RocketLauncher(1.0.1.10) as of yesterday and trying to adjust settings currently. Right now I can get around the NES stuff ok, but when it comes to my SNES games I can't seem to quit one and launch another game like it's taking too long to close it or it's incorrectly closing it. The error I'm getting is: There was an error waiting for the window "Snes9x ahk_class Snes9X: WndClass". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. I only see one version of Snes9x out on the web which would be 1.6 and I have that. Fade is naturally set to false as default so I'm not seeing anything else. RL's Global Default Exit Emulator Key is ~Esc however that doesn't work for Snes9 you have to hit Alt+F4, which does work however I feel like I'm missing a setting somewhere. I tried using a few other Snes emulators and did not like them.
Spawk Posted June 19, 2019 Posted June 19, 2019 That windows class error usually happens when using the wrong emu version. The module may have originally been written for 1.6 but then later changed to accomadate the change in windiw title.Try different versions of snes9x... that all being said, i too remember having difficutlies with the exit. So much as i did eventually got to another emu rather than spending a whole lot of time figuring it out.Good luck.Sent from my SM-A520W using Tapatalk
