MAME's wont runt without BetaBrite_Path
djbeto2209
When I try to run a MAME I get an error stating "Missing BetaBrite_Path and BetaBrite is enabled". What is BetaBrite and how do I adjust the settings? I have done some research and at the moment, I just want HyperSpin to run on my home PC and maybe sometime in the future I will put it in a cabinet.
I can run the roms going through my emulator but when I go through Hyperspin I get this error. Thanks in advance!
I have sneeky suspicion this related to Ledblinky. Have you got that switched on in HyperHQ.
Post your log if not.
My LedBlinky is disabled, so here is my log. Please let me know if you want more info.
11:39:43:492 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.0.9
11:39:43:492 | HL |     INFO  | +0     | Main - System Specs:
				HyperLaunch Dir: E:\Hyperspin
				OS: WIN_7
				Architecture: 64-bit (might not be accurate)
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 3840x1080 (3840x1080 work)
				Monitor #2 (\\.\DISPLAY2): 1920x1080 (1920x1040 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
11:39:43:492 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
11:39:43:492 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\HyperLaunch.exe exists
11:39:43:493 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Databases\Main Menu\Main Menu.xml exists
11:39:43:514 | HL |     INFO  | +15    | Main - HyperLaunch launched directly
11:39:45:113 | HL |     INFO  | +1591  | Main - HyperLaunch received "MAME" and "dkongj"
11:39:45:182 | HL |     INFO  | +78    | Main - dkongj is using the default emulator: MAME
11:39:45:182 | HL |     INFO  | +0     | Main - Checking for a [MAME] section in E:\Hyperspin\Settings\MAME\Emulators.ini
11:39:45:182 | HL |     INFO  | +0     | Main - Found [MAME] in E:\Hyperspin\Settings\MAME\Emulators.ini
11:39:45:193 | HL |     INFO  | +16    | CheckFile - Checking if E:\Hyperspin\Modules\MAME\MAME.ahk exists
11:39:45:228 | HL |     INFO  | +31    | Main - CRC Check - CRC matches, this is an official unedited module.
11:39:45:228 | HL |     INFO  | +0     | Main - dkongj will use module: E:\Hyperspin\Modules\MAME\MAME.ahk
11:39:45:232 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
11:39:45:234 | HL |     INFO  | +0     | Main - INI Keys read
11:39:45:234 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Module Extensions\7z.exe exists
11:39:45:251 | HL |     INFO  | +16    | CheckFile - Checking if E:\Hyperspin\Module Extensions\7z.dll exists
11:39:45:288 | HL |     INFO  | +47    | CheckPaths - Started
11:39:45:347 | HL |     INFO  | +46    | CheckPaths - Found rom: E:\Hyperspin\Emulators\MAME\Roms\dkongj.zip
11:39:45:347 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\MAME\mameuifx64.exe exists
11:39:45:550 | HL |     INFO  | +219   | CheckPaths - Ended
11:39:45:550 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 0
				frontendPID = 0
				frontendPath = E:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = E:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				emuFullPath = E:\Hyperspin\Emulators\MAME\mameuifx64.exe
				emuPath = E:\Hyperspin\Emulators\MAME
				emuName = MAME
				emuExt = exe
				romPath = E:\Hyperspin\Emulators\MAME\Roms
				romPathFromIni = E:\Hyperspin\Emulators\MAME\Roms
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = zip
				executable = mameuifx64.exe
				systemName = MAME
				dbName = dkongj
				romName =
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				logFile = E:\Hyperspin\HyperLaunch.log
				logLevel = 3
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = true
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = E:\Hyperspin\Media\Fade
				HLDataPath = E:\Hyperspin\Data
				HLMediaPath = E:\Hyperspin\Media
				HLErrSoundPath = E:\Hyperspin\Media\Sounds\Error
				modulesPath = E:\Hyperspin\Modules
				moduleFullName = E:\Hyperspin\Modules\MAME\MAME.ahk
				moduleName = MAME
				modulePath = E:\Hyperspin\Modules\MAME
				moduleExtension = ahk
				moduleExtensionsPath = E:\Hyperspin\Module Extensions
				libPath = E:\Hyperspin\Lib
				7zEnabled = false
				7zPath = E:\Hyperspin\Module Extensions\7z.exe
				7zDllPath = E:\Hyperspin\Module Extensions\7z.dll
				7zExtractPath = C:\Users\Megan\AppData\Local\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 1
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = E:\Hyperspin\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapper = ahk
				xpadderFullPath = E:\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = E:\Hyperspin\Profiles\ahk
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = E:\Hyperspin\Profiles\ahk\HyperSpin
				defaultProfile = E:\Hyperspin\Profiles\ahk\_Default
				systemProfile = E:\Hyperspin\Profiles\ahk\MAME
				xPadderSystemProfile = E:\Hyperspin\Profiles\ahk\MAME\_Default
				emuProfile = E:\Hyperspin\Profiles\ahk\MAME\MAME
				romProfile = E:\Hyperspin\Profiles\ahk\MAME\dkongj
				blankProfile = E:\Hyperspin\Profiles\ahk\blank
				HyperLaunchProfile = E:\Hyperspin\Profiles\ahk\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
11:39:45:553 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
11:39:45:553 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
11:39:45:577 | HL |     INFO  | +15    | BuildScript - Loaded User Functions Init.ahk script
11:39:45:577 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = MAME
				MEmuV =  v0.148
				MURL = http://www.mame.net/
				MAuthor = djvj
				MVersion = 2.0.6
				MCRC = D558F163
				iCRC = CD775A90
				MID = 635038268903403479
				MSystem = "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES"
				; Notes:
				; No need to edit mame.ini and set your rom folder, module sends the rompath for you.
				; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html
				; High Scores DO NOT SAVE when cheats are enabled!
				; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html
				; MAME 149 is currently bugged and HyperPause support is broken. Emu does not let you alt-tab out. This is a mamedev issue, not an HL one.
				; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1
				StartModule()
				FadeInStart()
				settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini")
				Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1)
				hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)	; Hides console window from view if it shows up
				pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1)	; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers
				bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1)	; "layout" or "normal"
				cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1)
				cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1)	; user defined key to be held down before launching a mame rom.
				sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1)
				romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1)
				mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1)
				Use_Bezels := IniReadCheck(settingsFile, "Settings", "Use_Bezels", "true",,1)
				Use_Bezels := IniReadCheck(settingsFile, romName, "Use_Bezels", Use_Bezels,,1)	; default is the system's current setting
				Use_Overlays := IniReadCheck(settingsFile, "Settings", "Use_Overlays", "true",,1)
				Use_Overlays := IniReadCheck(settingsFile, romName, "Use_Overlays", Use_Overlays,,1)	; default is the system's current setting
				Use_Backdrops := IniReadCheck(settingsFile, "Settings", "Use_Backdrops", "true",,1)
				Use_Backdrops := IniReadCheck(settingsFile, romName, "Use_Backdrops", Use_Backdrops,,1)	; default is the system's current setting
				If bezelEnabled = true
				{	ListXMLtable := []
					ListXMLtable := ListXMLInfo(romName)
					If bezelMode = layout
						useBezels := If (Use_Bezels = "true") ? "-use_bezels" : "-nouse_bezels"
						useOverlays := If (Use_Overlays = "true") ? "-use_overlays" : "-nouse_overlays"
						useBackdrops := If (Use_Backdrops = "true") ? "-use_backdrops" : "-nouse_backdrops"
						BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4])
					} Else {
						useBezels := "-nouse_bezels"
						useOverlays := "-nouse_overlays"
						useBackdrops := "-nouse_backdrops"
						BezelStart(,,ListXMLtable[2])
				; -romload part of 147u2 that shows what roms were checked when missing roms
				winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel"
				fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window"
				videomode := If (Videomode != "" ) ? "-video " . videomode : ""
				sysParams := If sysParams != ""  ? sysParams : ""
				romParams := If romParams != ""  ? romParams : ""
				StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1	; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms
				mameRomPaths := "-rompath """ .  (If mameRomName ? romPath : mameRomPaths) . """"	; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom
				If InStr(romParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If InStr(sysParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If mameRomName {
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension%	; rename rom to match what mame needs
					originalRomName := romName	; store romName from database so we know what to rename it back to later
					romName := mameRomName
					If ErrorLevel
						ScriptError("There was a problem renaming " . romName . "  to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8)
					Else	; if rename was successful, set var so we know to move it back later
						fileRenamed = 1
				If cheatMode = true
				{	If cheatModeKey	; if user wants to use a key to enable CheatMode
						cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : ""
					Else	; no cheat mode key defined
						cheatEnabled := "-cheat"
				If hideConsole = true
					SetTimer, HideConsole, 10
				Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate)
				If(ErrorLevel != 0){
					If (ErrorLevel = 1)
						Error = Failed Validity
					Else If(ErrorLevel = 2)
						Error = Missing Files
					Else If(ErrorLevel = 3)
						Error = Fatal Error
					Else If(ErrorLevel = 4)
						Error = Device Error
					Else If(ErrorLevel = 5)
						Error = Game Does Not Exist
					Else If(ErrorLevel = 6)
						Error = Invalid Config
					Else If ErrorLevel in 7,8,9
						Error = Identification Error
					Else
						Error = MAME Error
					ScriptError("MAME Error - " . Error)
				WinWait("ahk_class MAME")
				WinWaitActive("ahk_class MAME")
				BezelDraw()
				FadeInExit()
				BezelExit()
				If fileRenamed {	; rename file back to alternate name for next launch
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension%
					If ErrorLevel	; if rename was successful, set var so we know to move it back later
						ScriptError("There was a problem renaming " . romName . " back to " . originalRomName)
				FadeOutExit()
				ExitModule()
				ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution
					Global emuFullPath, emuPath
					ListXMLtable := []
					RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide
					Fileread, ListxmlContents, %emuPath%\tempBezel.txt
					RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent)
					RegExMatch(parent,"cloneof=" . """" . ".*", parent)
					RegExMatch(parent,"""" . ".*", parent)
					StringTrimLeft, parent, parent, 1
					RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle)
					RegExMatch(angle,"[0-9]+", angle, "-6")
					RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width)
					RegExMatch(width,"[0-9]+", width, "-6")
					RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height)
					RegExMatch(Height,"[0-9]+", Height, "-6")
					ListXMLtable[1] := parent
					ListXMLtable[2] := angle
					If (ListXMLtable[2]<>0)
						ListXMLtable[3] := height
					Else
						ListXMLtable[3] := width
						ListXMLtable[4] := width
					Else
						ListXMLtable[4] := height
					FileDelete, %emuPath%\tempBezel.txt
					Return ListXMLtable
				HaltEmu:
					If pauseMethod = 1
					{	disableSuspendEmu = true
						disableRestoreEmu = true
						PostMessage,0x211, 1, , , ahk_class MAME
					} Else If pauseMethod = 2
					} Else If pauseMethod = 3
						PostMessage,% 0x0400+6, 1, , , ahk_class MAME
					} Else If pauseMethod = 4
					} Else If pauseMethod = 5
						Send, {P down}
						Sleep, 1000
						Send, {P up}
				Return
				RestoreEmu:
					If pauseMethod = 1
					{	PostMessage,0x212, 1, , , ahk_class MAME
						WinActivate, ahk_class MAME
					{	PostMessage,% 0x0400+6, 0, , , ahk_class MAME
						Send, {P down}
						Sleep, 1000
						Send, {P up}
					} Else If pauseMethod = 6
				Return
				HideConsole:
					hideConsoleTimer++
					IfWinExist, ahk_class ConsoleWindowClass
					{	Log("Module - HideConsole - Console window found, hiding it out of view.")
						WinSet, Transparent, 0, ahk_class ConsoleWindowClass
						SetTimer, HideConsole, Off
					} Else If hideConsoleTimer >= 200
				Return
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class MAME")
				Return
11:39:45:581 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
11:39:45:581 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
11:39:45:581 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
11:39:45:581 | HL |     INFO  | +0     | Main - Module is built
11:39:45:581 | HL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\AutoHotkey.dll exists
11:39:54:932 | HL |    ERROR  | +9360  | Missing BetaBrite_Path and BetaBrite is enabled
11:39:54:932 | HL |     INFO  | +0     | ExitScript - Started
11:39:54:948 | HL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
11:39:54:951 | HL |     INFO  | +0     | ExitScript - Ended
My LEDBlinky is disabled.
My Log:
01:45:35 AM | HyperSpin Started
01:45:35 AM | Going FullScreen
01:45:35 AM | Checking for updates
01:45:35 AM | Update Check Complete
01:45:35 AM | Startup program unavailable
01:45:35 AM | Playing intro video
01:45:36 AM | Error intializing joysticks
01:45:36 AM | Menu Mode is multi
01:45:36 AM | Loading Main Menu.xml
01:45:37 AM | Main Menu.xml successfully loaded
01:45:37 AM | Main Menu wheel loaded successfully
01:45:41 AM | Loading MAME.xml
01:45:42 AM | Main Menu.xml successfully loaded
01:45:42 AM | MAME wheel loaded successfully
01:45:43 AM | Launching Game
01:45:43 AM | Using HyperLaunch
01:45:43 AM | Getting HyperLaunch path
01:45:43 AM | HyperLaunch located at E:\Hyperspin\HyperLaunch.exe
01:45:43 AM | Running HyperLaunch.exe
01:45:43 AM | HyperLaunch Command Line is: E:\Hyperspin\HyperLaunch.exe "MAME" "dkongj"
01:45:53 AM | Loading Main Menu.xml
01:45:53 AM | Main Menu.xml successfully loaded
01:45:54 AM | Main Menu wheel loaded successfully
01:45:54 AM | Exit program unavailable
01:45:54 AM | Quiting Hyperspin
01:45:55 AM | Bye!
Did you follow a guide to install Hyperspin etc? From you log it looks like Hyperlaunch is installed in your Hyperspin directory, is that correct?
Check this recent thread out. Post #13
www.hyperspin-fe.com/forum/showthread.php?34980-Help-launching-MAME-roms-in-HS/page2
If you need a written guide follow this.
www.hyperspin-fe.com/forum/showthread.php?29481-How-to-install-HyperSpin
Or follow my video guide, How to set up Mame in Hyperlaunch HQ and Hyperspin.
