Pharaoh84 Posted June 30, 2019 Posted June 30, 2019 I'm having an issue with getting a game to work that was working before and played numerous times without issue. The game is Silent Dragon on MAME. The game loads into a black screen with white squares and won't proceed into the title/start screen. I can push and hear the insert coin button working during the black screen and access the games test mode, but that's about it. Is there any way i can get the game to work again? I will provide photos if need be.
Creezz67 Posted June 30, 2019 Posted June 30, 2019 Hi, Just tested on latest Windows 10 update using MAME 0.211 and loads fine. tested silentd, silentdj, silentdu roms and all work as they should. Check that Windows defender is not blocking it if you think it should be working. Also update you graphics card drivers too as this may be causing the issue.
