AAE Emulator in Hyperspin
gunit
Ok, found the issue. Your exist key in the AAE emulator can't be the same as your exist key you have set in Rocketlaucher.
What causes the issue is exiting the emulator through it's proper exit key. If you set a different key in Rocketlauncher to exist your emulators, then Rocketlauncher just terminated the AAE emulator task and bring you back to hyperspin normally.
  • 2 months later...
Just reviewing this again as I never did resolve it. As the graphically error happens in Hyperspin, from launching in Rocketlauncher or direct from the Emulator, Styphelus fix is not the solution. I suspect Windows 10 is the issue.
So lots of investigating again and if I right click in windows and change the resoluion it fixes the issue ... hmmmmmm
