vaningo Posted August 21, 2019 Posted August 21, 2019 Hi all, Thanks in advance for viewing my issue. I recently added 3 systems to my set via rocket launcher - pc engine, c64, Vectrex and for some reason the names are repeated in the main system menu but without the themes just the blue default text. I have checked the database files and tried deleting and re-installing each set but the same thing keeps happening! Any ideas gratefully received
Penfold Posted October 10, 2019 Posted October 10, 2019 You need to go into the wheel settings and select the option for "parent only" if I remember correctly.
Creezz67 Posted October 10, 2019 Posted October 10, 2019 On 8/21/2019 at 8:17 PM, vaningo said: Hi all, Thanks in advance for viewing my issue. I recently added 3 systems to my set via rocket launcher - pc engine, c64, Vectrex and for some reason the names are repeated in the main system menu but without the themes just the blue default text. I have checked the database files and tried deleting and re-installing each set but the same thing keeps happening! Any ideas gratefully received Go to databases, then main menu.xml and look in there. Looks like you have duplicated the systems. Just edit this main menu.xml file and remove the lines of systems you do not want to show in Hyperspin.
vaningo Posted October 12, 2019 Author Posted October 12, 2019 Thanks but should of added my first port of call was the main menu xml which does not have any duplicates. I will try the wheel settings.
