sanxbr Posted October 5, 2019 Posted October 5, 2019 Hello guys, I'm facing some weirdo error. Recently I tried using 1.5.1 HS and got some error. I'll put the screenshot of it. Before the error I was using 1.3.3 HS with no problem at all but it seems like when I use the 1.5.1 some paths change and it begins looking for files on weird places. THis is my Tekken Collection wheel. The default emulator is "Tekken Collection" but each game has its own config on what emulator to use, all through RL. But, not to be mistaken, I created a system called "Tekken Collection" and put pcsx2 as its emulator. *log from RL 00:12:36:127 | RL | INFO | +N/A | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com) 00:12:36:257 | RL | INFO | +124 | Main - System Specs: RocketLauncher Dir: M:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Home Premium Total Memory: 16334.82 MB Free Memory: 13670.36 MB Used Memory: 2664.461 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GTX 1660 Ti GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 26.21.14.3648 Sound 1 Device: USB Audio Device Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: High Definition Audio Device Sound 3 Status: Enabled OS Language: English_United_States System Locale: pt-BR Formats Locale: pt-BR Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1600x1200 (1600x1160 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1600 Current AHK Desktop Height: 1200 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 00:12:36:257 | RL | INFO | +0 | CheckFile - Checking if M:\RocketLauncher\RocketLauncher.exe exists 00:12:36:267 | RL | INFO | +16 | Main - Using HyperSpin normal mode for version 1.5.1.0 found at: M:\HyperSpin.exe 00:12:36:267 | RL | INFO | +0 | Main - Raw CLI received: "Tekken 5 (USA). Tekken Collection -f M:\HyperSpin.exe -p HyperSpin" 00:12:36:267 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 00:12:36:267 | RL | INFO | +0 | Process.Process - "Exist" "HyperSpin.exe" 00:12:36:267 | RL | INFO | +0 | Main - Detected HyperSpin.exe is currently running 00:12:36:267 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1600 h1200 00:12:36:267 | RL | INFO | +0 | Main - RocketLauncher received "Tekken 5 (USA)." and "Tekken Collection" 00:12:36:267 | RL | INFO | +0 | CreateNewIni - Checking if an example file exists for Games.ini 00:12:36:267 | RL | WARNING | +0 | CreateNewIni - M:\RocketLauncher\Settings\Tekken 5 (USA).\Games.ini file not found, creating a new one. 00:12:36:267 | RL | INFO | +0 | CreateNewIni - Checking if an example file exists for Emulators.ini 00:12:36:267 | RL | WARNING | +0 | CreateNewIni - M:\RocketLauncher\Settings\Tekken 5 (USA).\Emulators.ini file not found, creating a new one. 00:12:36:267 | RL | INFO | +0 | CreateNewIni - Checking if an example file exists for RocketLauncher.ini 00:12:36:267 | RL | WARNING | +0 | CreateNewIni - M:\RocketLauncher\Settings\Tekken 5 (USA).\RocketLauncher.ini file not found, creating a new one. 00:12:36:267 | RL | INFO | +0 | Main - Did not find a "M:\RocketLauncher\Settings\Tekken 5 (USA).\Game Options.ini" file, skipping any game-specific options. 00:12:36:267 | RL | WARNING | +0 | RIniReadCheck - Created missing RocketLauncher ini key: "Default_Emulator" in section: "Roms" in "M:\RocketLauncher\Settings\Tekken 5 (USA).\Emulators.ini" 00:12:39:854 | RL | ERROR | +3588 | No Default_Emulator found in "M:\RocketLauncher\Settings\Tekken 5 (USA).\Emulators.ini" Please set one so RocketLauncher knows what module to use. 00:12:39:854 | RL | INFO | +0 | ExitScript - Started 00:12:39:857 | RL | INFO | +0 | ExitScript - Restoring HyperSpin.exe to x0 y0 w h1200 00:12:39:857 | RL | INFO | +0 | ExitScript - Checking what application is currently in focus. 00:12:39:857 | RL | INFO | +0 | ExitScript - ErrorLayer is currently active. Putting focus back on HyperSpin.exe with PID of 948 00:12:40:094 | RL | INFO | +234 | SystemCursor - Restoring mouse cursor 00:12:40:098 | RL | INFO | +0 | ExitScript - Restored cursor 00:12:40:098 | RL | INFO | +0 | ExitScript - Ended
Spawk Posted October 5, 2019 Posted October 5, 2019 You will probably have to set the log to "troubleshooting"... and possibly post it on RL forums. But just from a glance the period at the end of "Tekken 5 (USA)" looks very odd to me. As far as I know folders can not end in a period or it would see it as a file.
sanxbr Posted October 7, 2019 Author Posted October 7, 2019 Thanks for the reply! I managed to fix it by replacing everything using the fresh install of HS. Just had to add my systems on the mainmenu xml, forgot to copy it lol. But in the end I don't know what was the problem. Probably some .ini with wrong lines
