Rotate Hyperspin
DJDJDJDJ1
Hi,
I am planning to built an arcade game and run Hyperspin for front end. I downloaded a preconfigued Hyperspin environment. Everything seems to be working except when I launch hyperspin (windows 10 laptop), it launches everything sideways (90 degrees clockwise). Could someone please tell me how do I rotate it so it load properly on the laptop? I thought it might be a theme issue so I downloaded another theme and put it in the themes folder. However, I am not sure how to make Hyperspin use the new theme. This is where my knowledge of hyperspin finished. I have checked several tutorials and videos but I still cannot figure it out.
Thank you for any help.
we don't support the download or distribution of pre configured Hyperspins systems.
Hyperspin does not rotate to fit your monitor orientation or window settings.
You more then likely downloaded a  Vertical (rotated monitor) setup.  Each theme in that set up was built specifically for a rotated monitor.
You will need to remove and replace all the Vertical themes with standard themes and also change the position and style of wheel that displays all your   wheel images.
