robbyrage Posted April 7, 2020 Posted April 7, 2020 Hi guys. firstly I have tried to look through the forums to see if my query has been listed somewhere but i'm not getting anywhere with it so i'm looking for some guru support. I have installed bandits no nonsense pack on my shield and its a great little bundle, however it is missing some of my fav psx titles so I have tried to add them. - Moved over my romset and compressed it into the PBP format - Aquired artwork and vid files - copied them allover to the shield and updated the database file So I have the game loaded up within the category folder no problem however when I try to select it to run all I get is a black screen. When loaded outside of HS direct threw Epsxe it runs no problem, the same goes threw retroarch via Beetle PSX core but it will not run via pcsx core. I am unsure as to why its not running as my knowledge within the system is limited however I am guessing HS runs the pcsx core as default? Am I onto the right path here or am I way off. the full install settings are as they came. appreciate the help
thatman84 Posted April 7, 2020 Posted April 7, 2020 Please copy and paste the whole text from your playstation.ini file (or whatever you have it named) Also you will likely need an older version of RetroArch installed. Pre 64bit release. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
robbyrage Posted April 7, 2020 Author Posted April 7, 2020 [exe info] path=H:\hyperspin\Emulators\Sony Playstation\ rompath=Roms/Sony Playstation/roms/ userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=PBP,pbp,cue,cso,iso,img,bin parameters=cores/pcsx_rearmed_libretro_android.so searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false roms_only=false [themes] use_parent_vids=false use_parent_themes=false animate_out_default=false reload_backgrounds=true [wheel] alpha=.15 small_alpha = .5 style = normal speed = high pin_center_width = 500 horz_wheel_y = 512 vert_wheel_position=right y_rotation=right norm_large=360 norm_small=230 vert_large=450 vert_small=150 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style2 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=H:\hyperspin\Media\Sony Playstation\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=false remove_info_text=true use_last_game=true last_game=Chrono Cross CD2 random_game=false start_on_favorites=false [Special Art A] default=true active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [Special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [Special Art C] active=false x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active = true show_year = true show_manf = true show_description = true text_color1 = 0xFFFFFF text_color2 = 0xFFFFFF stroke_color = 0x000000 text_font = Style3 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640
robbyrage Posted April 15, 2020 Author Posted April 15, 2020 Ok guys, heads been boxed with it. Pretty certain I have a launcher issue as everything is from what I can tell bang on to play any new game I have entered into the database of hyperspin I am having to exit the frontend and go directly into expse I have the bandits no clutter install + have tried adding command and conquer and die hard trilogy to the setup, they are showing within the wheel but once engaged im just getting a black screen. any advice on whats going wrong would be great right now
