ruoverrated2 Posted June 14, 2020 Posted June 14, 2020 Hi, I have been setting up hyperspin on the NVIDIA Shield TV PRO. I have most of the emulators working (including Daphne) but I have an issue with a few wheels. For the Dreamcast and the playstation, it only shows a very limited amount of games. e.g. 007 - b* When I remove them from the database and make it start from c** then I only get to see games from c**-D. There are no filters enabled in the ini. settings. Is there another place that could be limiting the number of games visible?
Honosuseri Posted June 15, 2020 Posted June 15, 2020 It's probably an ampersand (&) and apostrophes being used. Check the system xml file, see if it uses "&" and "&apos". Make a backup of the xml file, use notepad++ to find and replace & with &. "There is so much more and beckons me. To look through to these, infinite possibilities..."
kerryelliott Posted July 20, 2020 Posted July 20, 2020 Thank you so much! Now everything it's clear! 8 ball pool
