HyperMarquee and LED Blinky
Hi Folks,
Finally got around to setting up HyperMarquee - which of course requires some jiggery pokery with LEDBlinky. Which is a bit unfortunate as now my LED buttons have, inevitably, stopped working in HyperSpin. Anyone got any ideas?
  • 1 month later...
Hey bro, im sorry for breaking into your topic, but i was wondering, i just set up hypermarquee with hyperspin, all works well except , that when i close i game after i finish playing it, hyperspin looses focus and i have to press escape like for every image hypermarquee loaded, until the last one, and then hyperspin gains focus again.  I did a test with hyperspin and mame in window mode and notice that for every game hyperspin wheel loads, hypermarquee opens the image of that game, so if i look at 20 games before chossing one in hyperspin, hypermarquee opens like those 20 images at the same time, so in order to have hyperspin gain focus again i have to press escape 20 times to closed each image. Its there an option im missing to prevent this? hope you can help. thanks.
  • 4 months later...
Hey abispac, I had the same issue. HyperMarquee had a new window for every picture. I had the wrong type of IPC Method (inter-process communication). I had HyperSpin EDS set to CLI which initiates a new instance every time. Once I switched the IPC Method to Pipe, it kept the connection open and I only have one instance of Hyper Marquee now. Sounds like you are using HyperSpin directly. You might find a similar option.
