stripey Posted September 26, 2020 Posted September 26, 2020 Ive added the .dll file fix to windows 10 in the root folder - hyperspin launches now but hyperHQ wont still - any ideas/ suggestions?
aceman2112 Posted October 1, 2020 Posted October 1, 2020 Mine STILL Won't Launch With the File. And I Enable the File .I'm at my WITS END on this,however my Big BOX works fine,go figure.
Creezz67 Posted October 1, 2020 Posted October 1, 2020 On 9/26/2020 at 11:59 AM, stripey said: Ive added the .dll file fix to windows 10 in the root folder - hyperspin launches now but hyperHQ wont still - any ideas/ suggestions? Try and Disable antivirus (defender) and firewall and test again Both work fine on Windows 10 with 2004 update.
aceman2112 Posted October 1, 2020 Posted October 1, 2020 Um yes on that to,nothing happens.Worked fine on 1909,Unfortunatly I can't go back to 1909.
thelikelylad Posted October 5, 2020 Posted October 5, 2020 I'm having the same issue where exactly do I place the sxs.dll file?? is it in the route of the hard drive D: or somewhere else??? help would be much appreciated.
robmoto Posted October 5, 2020 Posted October 5, 2020 Hi , same here , Hyperhq doesn't work , even if I disable Windows Defender and antivirus.
Creezz67 Posted October 6, 2020 Posted October 6, 2020 11 hours ago, robmoto said: Hi , same here , Hyperhq doesn't work , even if I disable Windows Defender and antivirus. Works fine for me on 2004 update and 1909 (Windows 10 Pro & Windows 10 Home 64bit) Put sxs,dll inside folder where Hyperspin.exe is Set exclusion in Windows Defender for the drive you have Hyperspin on. Ensure you disable all firewall ports, to see if this helps.
