magnemmar Posted September 27, 2020 Posted September 27, 2020 Hyperspin wasn't launching, and I downloaded the sxs.dll patch today. Now Hyperspin starts up, but it freezes on the launch video (so far two out of three times). I'm not sure what might be causing this issue, but I don't think I've ever seen this behavior in the past. Anything I should check, or information I can provide that might be helpful? I'm on HS v1.5.1 (patched), Windows 10 Pro, 64bit. OS Build 19041.508, Feature Experience Pack 120.2212.31.0
Creezz67 Posted September 28, 2020 Posted September 28, 2020 18 hours ago, magnemmar said: Hyperspin wasn't launching, and I downloaded the sxs.dll patch today. Now Hyperspin starts up, but it freezes on the launch video (so far two out of three times). I'm not sure what might be causing this issue, but I don't think I've ever seen this behavior in the past. Anything I should check, or information I can provide that might be helpful? I'm on HS v1.5.1 (patched), Windows 10 Pro, 64bit. OS Build 19041.508, Feature Experience Pack 120.2212.31.0 Turn off windows defender or set exclusion for the drove Hyperspin is on. Also make sure you set Hyperspin.exe to run as admin (right click, properties then tick set as admin)
