yuljk Posted December 31, 2020 Posted December 31, 2020 Hi guys - I'm trying to get Hyperspin working with ExoDOS v5, however the games refuse to launch. The games are in .zip format - I've setup the emulator in RL for zip extensions. I've created a MS-DOS.xml with HyperROM2XML and I can see all of games when performing an audit in RL. I've also renamed the Microsoft MS-DOS.ini in the RL modules 'Zipmapping' folder. If anyone ha got this working, any help would be appreciated.
Spawk Posted December 31, 2020 Posted December 31, 2020 Will probably have to set skipchecks to "Rom only" as well.
Guest Posted December 31, 2020 Posted December 31, 2020 The RL dosbox module needs a slight update to work with v5. I have this working locally, should get posted to RL forums at some point soon. Sent from my iPhone using Tapatalk Pro
yuljk Posted December 31, 2020 Author Posted December 31, 2020 Thanks fellas - I have 'skip ROM checks' to 'rom only' I'll keep an eye on the RL forums. Also - just to confirm, my rom paths should have both the directory where all the .zipped games are as well as the !dos folder? - The module notes were a little tricky to understand. Many thanks
Guest Posted December 31, 2020 Posted December 31, 2020 Thanks fellas - I have 'skip ROM checks' to 'rom only' I'll keep an eye on the RL forums. Also - just to confirm, my rom paths should have both the directory where all the .zipped games are as well as the !dos folder? - The module notes were a little tricky to understand. Many thanksYes. Won’t work until module, xml and zip map are updated though. Sent from my iPhone using Tapatalk Pro
yuljk Posted December 31, 2020 Author Posted December 31, 2020 5 minutes ago, tonesmalone said: Yes. Won’t work until module, xml and zip map are updated though. Sent from my iPhone using Tapatalk Pro Thanks tonesmalone - I eagerly await the new module
