Games won't launch in HyperSpin
maverickmks
Hello Community,
I'm running HyperSpin 1.5.1 with RocketLauncher 1.2.0.1 and RocketLauncher UI 1.0.1.10.
Each time I launch HP from RL, it loads the wheels okay and I can select an emulator.
However, when I try to start a game, it never loads.
I've checked:
the key mapping in HHQ
the settings ini for HP points to the RL exe
permissions of the relevant exe...basically set everyting to admin pri in desperation
***I've added some files that may help diagnosis my issue(s).
Peace
K
hyperspin log.txt hyperspin settings.txt
RL settings.txt
Hello Spawk,
Thanks for helping out.
I read your post, and all that needed changing was removing the exe path from HHQ. Interestingly my RL logs are empty even after a refresh and all filters removed.
I believe my mame is 200
Peace
K
Ok you can skip the updated module then.
Need an RL "troubleshooting" log though. It should create one (or overwrite the existing one) every time you try to run a game.
Not really, has always just worked for me.
Not sure what you mean by cleared? There is never a need to manually edit this file. Simply delete the file, hopefully it will create a fresh one after you try a game.
Try setting skipchecks to “rom only”... sorry I am at work right now.
I updated both options in RL.
I also updated the RL mame module and mame to the latest version 227 but the issue persists.
I hoping we can eventaully get it to work.
The lastest RL logs are also attached
RL. log
