sushko Posted March 6, 2021 Posted March 6, 2021 Hi the settings in HypeHQ don't work for wheel settings. I just want to setup the wheel not to spin for 5min. It starts to spin in like 30 seconds or faster. Any help would be appreciated.
Spawk Posted March 6, 2021 Posted March 6, 2021 Attract Mode should be working fine. If you set the slider in HQ to 5 min and it doesn't seem to work, I can think of 2 possibilities: 1. Your settings ini is set to "read only". Open it in notepad and make sure under [AttractMode] it is set to "Time=300" (5 min in seconds). 2. Using the "joystick" options in HQ has been known to cause uncontrollable wheel movement. People generally use the "Startup Script" or a keymapper to control HS instead.
sushko Posted March 6, 2021 Author Posted March 6, 2021 Thank you I will check this and let you know.
sushko Posted March 7, 2021 Author Posted March 7, 2021 OK I took a look at this and I can edit the settings ini. It was set at 300 seconds so I set it to 600 seconds. It doesn't respond if I set it to false it won't spin at all so it's just the timer. It seems to be stuck on 10 seconds.
